March 24, 2026, 12:06:35 AM *
Author Topic: Motorcycle headlights  (Read 1426 times)
« on: May 25, 2011, 05:55:55 AM »
With gas conscious commuters buying small 2 wheeled commuter bikes/scooters it is noticeable how many have badly aimed headlights that from a distance look like the dying flicker of a lightning bug.
When last did you stand 50 yards ahead of your bike to check it's headlight alignment?
As Daniel Meyer has previously demonstrated old bulbs lose quite a bit of their lighting potency. Maybe you need to think about that as well?
rmrc51
Palmyra, Virginia
« Reply #1 on: May 25, 2011, 07:42:41 AM »
Good point!  cooldude
Think I'll check mine.
VRCC # 30041
Lyn-Del
Houston area
« Reply #2 on: May 25, 2011, 07:29:58 PM »
I know a few weeks ago, coming home at night I found that the headlight on that bike didn't quite make it across the intersection.
It's fixed now!
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: May 25, 2011, 10:16:41 PM »
Since I run on high beam with a modulator during the daytime and a lot of time at night, I check both high and low beams everytime I ride.  I use SilverStar Ultras for the increased light output with the knowledge I might have to replace the bulb yearly since they burn out faster.  It's a trade off I'm willing to live with.
Marty
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #4 on: May 25, 2011, 11:59:48 PM »
I switched to that same bulb, recently. I also have gone out in front, and looked hard at my lights, and the one thing I DID change, is my 55W lights on the Cobra light bars - the 55W were great, with the headlight on bright, but TOO  bright for normal running, IMO, and since I leave them on all the time, I went to 35W'ers. I like them a LOT better. If I ever decide to switch my running lights with the bright switch, I'll change them back
R
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
Cliff
Manchester, NH
« Reply #5 on: May 26, 2011, 03:38:51 AM »
Marty
What he said  ^^^^^^    cooldude
VRCC # 29680
MacDragon
My first Valk VRCC# 32095
Middleton, Mass.
« Reply #6 on: May 26, 2011, 03:53:13 AM »
I've got a couple bikes and check the angle frequently... Very good point and observation. cooldude
Patriot Guard Riders
slider
mulberry arkansas
« Reply #7 on: May 26, 2011, 06:41:39 AM »
can anyone post correct way to aim headlight??I kno which adjustment screw does what but as far as   aiming  Im.lost.thanks guys
a proud navy veteran
X Ring
« Reply #8 on: May 26, 2011, 07:46:21 AM »
Here's one thought on headlight aiming.  http://www.webmaster10.com/ldr/headlight_aiming.html
Marty
slider
mulberry arkansas
« Reply #9 on: May 26, 2011, 07:57:44 AM »
thanks Marty.!
