Lt.Gene
« on: May 25, 2011, 02:46:32 PM » |
I just returned from a two thousand mile trip on my 99 Interstate and my two driving lights and one headlight burned out. I am having trouble replacing the headlight because I cannot disconnect the plug. I have read several posts for help and it seems the solution is to continue pulling on the plug. My question, is the connector a pinch plug or is there something holding the plug to the lamp. I have squeezed all sides of the plug as best I could until my fingers hurt--still no luck. Thanks
Thunderbolt
« Reply #1 on: May 25, 2011, 03:12:23 PM » |
once you get the rubber cover off. Probably best to put a glove on, it may release and cause a big uh-oh on the back of your hand if you are like me. The wire clip is a little finicky too. Press in and move to the side to release so the bulb will come out.
Lt.Gene
« Reply #2 on: May 25, 2011, 11:05:16 PM » |
Well, perseverance paid off. I pulled and pulled and the connector finally released. Then while placing the replacement bulb in place, it slipped and fell into the headlight housing. Could not get it out so I ended up removing the fairing completely, using some needle nose plyers and getting it out. Replacing the bulbs was a piece of cake after that. Thanks for the reviews!
Lt.Gene
« Reply #4 on: May 26, 2011, 08:26:12 AM » |
Yeah Fred, I followed that article until I dropped the darn bulb into the housing and could not retrieve it with the limited access having the fairing on the bike. No problem when I took it off which I really did not want to do. Turned a relatively short job into a much longer, more involved one. Thanks for the tip though.
Grey wolf oz
« Reply #5 on: November 05, 2022, 12:00:07 AM » |
Well “that was fun” is not really the first thing that comes to mind,, However I deliberately did both bulbs The second took about 10% of the time effort and cursing, Chanel locks get to the plug nicely !! I used automotive bulbs Where do i get the adaptor rings ? Luke
0leman
« Reply #6 on: November 06, 2022, 08:10:20 AM » |
Luke, you don't need an adaptor if you remove the two lower wings from the bulb. I have used auto bulbs since 2008 with no adaptors. I do remove the speaker panels as have fairly big hands. Those with smaller hands have and do change the bulbls without remove anything. The springs removal/replacement do cause problems and sometimes some interesting phrases sort of like putting the driveshaft into the U-Joint.
2006 Shadow Spirit 1100 gone but not forgotten 1999 Valkryie I/S Green/Silver
« Reply #7 on: November 06, 2022, 01:37:35 PM » |
It is definitely a practice thing
Challenger changed my bulbs out in Lacrosse maybe 10 or more years ago while drinking a beer
I mean he never even put it down
Now that is talent
Grey wolf oz
« Reply #8 on: November 08, 2022, 04:59:09 PM » |
Luke, you don't need an adaptor if you remove the two lower wings from the bulb. I have used auto bulbs since 2008 with no adaptors. I do remove the speaker panels as have fairly big hands. Those with smaller hands have and do change the bulbls without remove anything. The springs removal/replacement do cause problems and sometimes some interesting phrases sort of like putting the driveshaft into the U-Joint.  yes,,, donated some blood and educated the Neighbours with colorful expletives, thanks
Grey wolf oz
« Reply #9 on: November 08, 2022, 05:00:08 PM » |
Now that is talent
never spilled a drop,,, dedication !
