February 02, 2026, 01:30:30 PM *
Author Topic: Pilot Screw Adjustment Tool  (Read 6885 times)
Red Diamond
Beaumont, Texas
« on: May 27, 2011, 12:22:30 PM »
Does anyone know whether this tool from Motion Pro is a good tool to use when adjusting the pilot screws without removal of the carb bank from the Valkyrie? Any info would be appreciated. TIA
http://www.motionpro.com/motorcycle/partno/08-0229/
Bobbo
Saint Charles, MO
« Reply #1 on: May 27, 2011, 12:39:44 PM »
I haven't had good luck with it.  The D socket is a little too large to fit well into the recess in the carb, and the 90 degree gear drive is very rough.  You can't tell when you bottom the screw since the turning force needed to run the gear is more that what it takes to set the needle.  I modified the socket by turning it down a little, and use flex or short drive tools to turn the screws.
Red Diamond
Beaumont, Texas
« Reply #2 on: May 27, 2011, 01:03:09 PM »
Thanks Bobbo, I won't waste the money.
« Reply #3 on: May 27, 2011, 02:55:32 PM »
this is the best honda tool to get if u can find one. honda discontinued it for some reason, it was org listed for the cbr900.  do a google search, some sites still show it avail. Good Luck
it has a flexible spring head. been using it for yrs.
07MMA-MT3010B WRENCH PILOT SCREW
« Reply #4 on: May 27, 2011, 06:59:53 PM »
I  have one and like it but its not perfect like Bobbo said the fitting is a bit big I shaved mine down and lubed the gears now works well. The other thing is you will have to get used to the angle and feel to get a proper adjustment
rodeo1
« Reply #5 on: May 27, 2011, 07:35:14 PM »
i bought the head that fit the screws, cut off the end of one of them universal screwdrivers to use as a mount for the driver, about 3 inches long, looks like a little screwdriver. i have to pull the intake runners, but that is a peice of cake, don't need to remove the carbs.
RonW
Newport Beach
« Reply #6 on: May 27, 2011, 08:26:16 PM »
Red Eye Technical Services (scroll down)
http://sites.google.com/site/valkparts/
http://redeye.ecrater.com/p/5604503/stubby-pilot-screw-tool-on-bike
« Last Edit: May 27, 2011, 08:34:50 PM by RONW » Logged
2000 Valkyrie Tourer
ILcruiser
Crystal Lake, IL
« Reply #7 on: May 27, 2011, 10:07:30 PM »
That's the one I have, it works great.  I put some of the lady's nail polish on one corner to make it easier to count turns.  It's easier to use with the intake tubes pulled, but can be done with them in place.
1999 Valkyrie Standard
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #8 on: May 27, 2011, 10:37:59 PM »
THE TOOL THAT CA EXHAUSTCOATINGS IS SPEAKING OF IS THE BEST, AND EASIEST ONE TO USE WITH EVERYTHING IN PLACE....IE INTAKES ETC..
hueco
WACO,TEXAS
« Reply #9 on: May 27, 2011, 10:59:57 PM »
I got one of those. It worked great. Until I put it on the head of a screw that was locked up. It rounded the corners off the brass . I took one of the jets to work where we have an EDM. The EDM operator burnt one out of CRS. Fits perfect and will not round the corners off like brass.
« Reply #10 on: May 28, 2011, 06:27:50 AM »
Once the pilots are removed, I cut a slot in the end for a normal screwdriver and add a bit of never-seize to the threads before reinstalling them..
« Reply #11 on: May 28, 2011, 06:28:06 AM »
Red Diamond
Beaumont, Texas
« Reply #12 on: May 28, 2011, 08:27:35 AM »
Thanks for the input from all.
Chiefy
Sarasota, Florida
« Reply #13 on: May 29, 2011, 07:05:19 PM »
I have this one also.  A bit cumbersome with my fat fingers, but a little patience goes a long way with the tool.
quexpress
Montreal, Québec, Canada
« Reply #14 on: May 29, 2011, 07:41:08 PM »
Same here Patrick!
I have picked up that tip from you quite a while back on the original tech board.cooldude
Thank you!  Cool
I still have a full deck.
I just shuffle slower ...
