February 02, 2026, 01:37:59 PM *
Author Topic: Alternator cover  (Read 2060 times)
dubsider
Flat6 baby #33034
Dublin GA
« on: May 31, 2011, 07:13:18 AM »
my alternator cover wants to keep popping out at the pin that slides into the grommet (top).. I tried loosening the bolt slightly in hopes that it would give the pin a little more length as I push it in.. but no luck.  It does snap into place but always pops out.. any ideas???
9Ball
« Reply #1 on: May 31, 2011, 07:33:07 AM »
JB weld?    Grin
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Joe Hummer
Arnold, MO
« Reply #2 on: May 31, 2011, 07:44:46 AM »
Replace the grommet...Part Number 83551-300-000...
Item 21 on this page:
Alternator Fiche Page
Joe
1999 Valkyrie Interstate
« Reply #3 on: May 31, 2011, 09:44:29 AM »
I don't have my alt cover and motor handy to look at, but I had the same problem. You are installing it wrong.
Isn't there another tab with a rubber boot? So there are 3 points that need to be put in correctly. I think you are installing it wrong, it took me 3 times to fit it right.
« Last Edit: May 31, 2011, 11:04:59 AM by gordonv » Logged
dubsider
Flat6 baby #33034
Dublin GA
« Reply #4 on: May 31, 2011, 11:08:38 AM »
I think you are correct.. I looked more closely and there is a tab on the center left that fits into a slot that does not seem to be aligning properly..   I will check that out tonight.
dubsider
Flat6 baby #33034
Dublin GA
« Reply #5 on: May 31, 2011, 05:14:27 PM »
Hallelujah Hallelujah ....  mission accomplished.   coolsmiley
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #6 on: May 31, 2011, 07:22:42 PM »
dubsider.....you actually have 4-places that connect the cover....the bolt on the botton/the slotted tab in the oval grommet/the pin that goes into the round grommet/...and the rubber connector that is on the alternator frame that goes into the retangular raised piece on the cover itself (this rubber is called:  rubber protector...#5 on micro fitch under alternator section).  this little rubber has a habit of falling off when you remone the cover, and you don't see/don't miss it when you put in back on.  when you put it back on, put a little dab of silicone on it, and it won't fall off again.
