February 02, 2026, 01:38:07 PM *
Author Topic: Electronic Cruise control.  (Read 1724 times)
Ghost Rider 2
Downs, Illinois
« on: May 31, 2011, 05:16:46 PM »
     Wanting to put a cruise control on my Valkyrie.  I have a McCruise on a Kawasaki Concours works great.  But just wondering with the 6 carb set up how a vac control system will work.  Just looked at an audiovox system that is non vac controled.  Would like to hear from someone that is using an audiovox set up.  Thanks
Bob E.
Canonsburg, PA
« Reply #1 on: May 31, 2011, 05:50:43 PM »
I have the audiovox ccs vaccum system and it works great.  I installed it myself with the instructions posted on ShopTalk.  It works great...highly recommended.
designer
Columbus, Ohio
« Reply #2 on: May 31, 2011, 06:07:17 PM »
I installed one, I had to use the vacuum can to get it to work, it's good +1/-3mph with no tinkering. Use it all the time.  Best 150 dollars I ever spent
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
Valk1520
West Olive, MI
« Reply #3 on: May 31, 2011, 06:44:09 PM »
I stressed about doing the mod for some time, thinking it would be to complicated.  Took on the task during the winter a couple years ago, it wasn't that difficult and finished it quicker than I thought.  Works GREAT  cooldude and I would do it again if I found another Valk (and another Audiovox).
alph
Eau Claire, WI.
« Reply #4 on: May 31, 2011, 07:08:25 PM »
i installed the audiovox cruise this last summer, i use it everyday i go to work (for my short 10 mile drive) holds great, didn't use a vacuum canister, just went off of carbs 1 and 2 with a check valve for each, and a "T" between 'em.  i also tied the cable in on the throttle cross bar unlike the instructions posted on the install.  drilled and tapped a 4mm hole to hold the servo cable.
Ghost Rider 2
Downs, Illinois
« Reply #5 on: May 31, 2011, 07:37:12 PM »
   I see a cruise control in my very near future.  I did 350 miles on the bike yesterday. I have done 5 and 6 hundred a day on the Goldwing.  I like the cruise it takes some of the cramp out of the wrist.
