February 02, 2026, 03:14:46 PM *
Author Topic: 3 Shim washers under needles on 97 Carbs????  (Read 1918 times)
petevenne
Concord NH
« on: June 04, 2011, 02:43:01 PM »
3 Shim washers under needles on 97 Carbs???? Bought a set of 97 carbs from Pinwall to rebuild. After inspecting slides and needles I found 3 washers under all the needles.. My 99 intersate carbs only has 1 shim washer per needle.. Carbs run great but smells gassy... Plugs are pinkish tan...
Any Ideas??
Thanks, Pete
« Reply #1 on: June 04, 2011, 02:59:05 PM »
The 3 washers are not stock, they were added probably due to a wild ass set of 6 into 6 drag pipes were on it and they were trying to get back the horse power lost, OR, the bike came from the mountain area.
Take them out and don't worry about it.
Momz
ABATE, AMA, & MRF rep.
« Reply #2 on: June 04, 2011, 03:52:54 PM »
Three Shims and only six carbs,...who woulda thunk?
ALWAYS QUESTION AUTHORITY!
petevenne
Concord NH
« Reply #3 on: June 04, 2011, 03:58:39 PM »
3 shims per needle, to be clear...
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #4 on: June 04, 2011, 06:15:52 PM »
I shimmed my needles too, years ago. Forgot about that. Interstate springs, shimmed the needles
(2 shims per needle) and switched from Dyna Ignition to a six degree trigger wheel, K&N Filter, no pre-filter.
petevenne
Concord NH
« Reply #5 on: June 05, 2011, 03:51:57 PM »
I have stock exaust, stock aircleaner, 38 pilots and ECT mod.. ... Never had the Mofo top end, untill the the 3 shims ???
 Goes like a Raped Ape.... Don't even use the choke anymore......Still smells gassy?? 1,2 OR 3 Shims???
Ratdog
Somewhere out West, Which way did I go?
« Reply #6 on: June 05, 2011, 10:23:14 PM »
I found just the opposite coming over the Rockies enroute to one of the IZs... I was almost pouring raw fuel out the Vikings and had to stop and drop my needles a couple of clicks until I dropped down into the lower elevations again... then stop and raise 'em back up to feed it more juice.
Make yourselves sheep, and the wolves will eat you. - Benjamin Franklin. If it ain't Zesty, it's only a two-tone.
« Reply #7 on: June 06, 2011, 09:29:50 AM »
Way too much!
Probably the result is low mpg figure.
Toss the extra shims, they're not helpful and they cost you mileage.
Not having to use the choke. With the 38's it's like your running with the choke "on" all the time!
