January 28, 2026, 12:37:39 PM *
Author Topic: Goldwing Question about old wings  (Read 2796 times)
Old Geezer Richard
San Antonio , Tx
« on: April 18, 2009, 10:51:14 PM »
 I have a 1980 1100 Goldwing with a worn out engine .... I have a friend who has a 1200 engine just dying to be used .... My question is does anybody know if I can fit that 1200  motor into a 1980 1100 standard frame and work ..... will it bolt up or will I have to change the motor mounts .... and will the drive shaft work on my rear drive unit  , I'm kinda thinking that 1200 is wider than the 1100 .... the 1200 engine is cheap and running with fairly low mileage ( free to me ) just come and get it out of the garage if its too much bs than I'll just shop around for a descent 1100 engine .....  I need some  VRCC wisdom ..... Thanks Old Geezer Richard
Bagger John - #3785
« Reply #1 on: April 19, 2009, 03:30:11 AM »
In a nutshell:
No, you can't.
Too many differences between the model years, and it'll be cheaper to buy a used 1100 motor and put that the '80.
Describe "worn out" to me...how many miles on the GL1100 engine?
Old Geezer Richard
San Antonio , Tx
« Reply #2 on: April 19, 2009, 08:14:44 PM »
 Hey BaggerJohn my old wing had 225,000 miles on it before it gave up the ghost .... I had oil pump up into the radiator over flow container with oil for some reason .... I think the the water pump  seal must have gone out , and believe it or not there was no water in the oil  ....  well anyway I'll just keep an eye out for a low mileage 1100 engine that I can put in this summer after the Inzane ... Thanks Old Geezer Richard
Bagger John - #3785
« Reply #3 on: April 20, 2009, 06:23:52 AM »
You have a PM...
Zorba
Ride the Dragon
« Reply #4 on: April 20, 2009, 09:14:20 AM »
Ask " goldwingfacts.com " great bunch of guys !
