February 03, 2026, 02:16:50 AM *
Pages: 1 [2]   Go Down
Author Topic: THE DREADED SATANIC HYDROLOCK  (Read 16625 times)
dalai-lama
Wish I was out riding...
Watertown CT
« Reply #40 on: June 20, 2011, 07:16:10 AM »
Just order the parts from
http://www.directlineparts.com/
The rear case is under $180.  The only part I had trouble with is the one bearing that has the wrong part number in the fiche.  I never did find the right bearing and just cut out the old one from the broken case and re-used it.  Order dowels as well for both the clutch cover and the rear case.  You might lose one or one might not come out.
Here was my initial order:
PRODUCT INFORMATION:
Mfg Product Number: 21110-MZ0-000
Description: CASE, RR.            for 1998 HONDA GL1500CT
Order Quantity: 1
Unit Price: $176.41
Total Cost: $176.41
Mfg Product Number: 21112-MN5-650
Description: GASKET, RR. CASE     for 1998 HONDA GL1500CT
Order Quantity: 1
Unit Price: $24.00
Total Cost: $24.00
Mfg Product Number: 91204-MN5-005
Description: OIL SEAL (28X48X9)   for 1998 HONDA GL1500CT
Order Quantity: 1
Unit Price: $7.73
Total Cost: $7.73
Mfg Product Number: 91316-PE7-730
Description: O-RING (62.4X3.1)    for 1998 HONDA GL1500CT
Order Quantity: 1
Unit Price: $2.50
Total Cost: $2.50
Mfg Product Number: 28106-MN5-010
Description: GEAR (19T)           for 1998 HONDA GL1500CT
Order Quantity: 1
Unit Price: $18.49
Total Cost: $18.49
Mfg Product Number: 90241-MB0-000
Description: NUT, LOCK (30MM)     for 1998 HONDA GL1500CT
Order Quantity: 1
Unit Price: $12.77
Total Cost: $12.77
Mfg Product Number: 90545-300-000
Description: WASHER, OIL BOLT     for 1998 HONDA GL1500CT
Order Quantity: 1
Unit Price: $2.50
Total Cost: $2.50
Mfg Product Number: 90206-MZ0-000
Description: NUT, HEX. (22MM)     for 1998 HONDA GL1500CT
Order Quantity: 1
Unit Price: $6.10
Total Cost: $6.10
Mfg Product Number: 83700-MZ0-000ZH
Description: CVR, CENTER *R223P*  (PEARL SEDONA RED) for 1998 HONDA
GL1500CT
Order Quantity: 1
Unit Price: $199.15
Total Cost: $199.15
ORDER TOTALS:
Item Total: $449.65
Tax: $0.00
Shipping: $0.00
Order Total: $449.65
I then ordered the two bearings in the case separately.  The smaller one has the bad part number!
My center cover was broke so I ordered that at the same time.  I ordered this from Amazon and it worked perfectly for the output shaft nut:
http://www.amazon.com/Sunex-SUN2802ZD-Spindle-Impact-Socket/dp/B0015PKSPG/ref=pd_1
Good luck and take your time.
the dalai
the dalai
Bigun
VRCC# 32964
Monroe, Iowa
« Reply #41 on: July 16, 2011, 01:50:13 AM »
  Have nothing but time, LOL the Girlfriend decided to kick me out so the money I had set aside for fixing the bike had to go into moving. Have plenty of OT lined up in the near future though so I'll be able to start ordering parts soon, just sucks seeing my pride and joy sitting all alone in the garage waiting. Also what fuel filters are you guys using with the Pingle petcocks?  Decided to get that posibility out of the way ASAP.
1999 Valkyrie Interstate
Garland
#618
Hendersonville NC
« Reply #42 on: July 16, 2011, 05:37:28 AM »
Mine hydrolocked a couple years ago, broke some teeth off the starter and idler gears. I think all the parts were maybe $150, and it took me three weekends to repair mostly because of making or locating the three sockets I needed that I did not have.
I think the fear of hydrolock may be overstated, but it is a good thing to be aware of-especially if you smell gas before starting.
« Last Edit: July 17, 2011, 07:39:58 AM by Garland » Logged
« Reply #43 on: July 16, 2011, 07:25:13 AM »
There is a whole of info on this fuel-lock subject thats been posted over the years.. As far as filters are concerned,, I use a plain ole filter readily purchased at any fuel filter store.. Wink  .. Some say they have had flow problems,, I haven't..  I still believe that the Pingle and filter are the best remedy to try and eliminate the fuel-lock..
Pages: 1 [2]   Go Up
