February 02, 2026, 04:44:16 PM
Motorcycle but not Valc Related
Topic: Motorcycle but not Valc Related (Read 1529 times)
Fathertime
Washington County, New York
June 12, 2011, 12:37:20 PM »
Needing some advice for my son about his '08 ZZR.
The bike is a tad too tall for him, and he was asking dad what he had to do to lower it by about 2". Rather than admitting I have no idea, I thought I'd ask some real gear heads about what is involved in such a project.
What needs to be done? Is it mostly a matter of removing some suspension parts and bolting on new?
Are there any drawbacks to such a project? Such as adverse effects on handling and so on?
Thanks in advance for any comments.
Rich
six2go #152
Ft. Wayne, IN
Re: Motorcycle but not Valc Related
June 12, 2011, 01:15:30 PM »
Does it have rear shocks like the Valk? If so, you can probably install shorter ones. If it's a single shock like on my V-Strom, you can get(maybe) longer "Dogbones" which will lower it. I've done that on the Strom. I would imagine the forks can be "slipped" in the trees to lower the front by the same amount. Then either a custom seat or modify the stock one. 2" is a lot to lower a bike without compromising ground clearance.
sailed2japan
June 12, 2011, 04:55:40 PM »
It would seem that lowering links are out there and readily available. should be as easy as bolting a pair one, adjusting them to were you like, then matching by adjusting the front forks, as you stated. The only draw backs would be that you will have a little less clearence underneath and lower lean angles. IMHO, 2 inches wouldn't worry me on that bike.
valkyriemc
NE Florida
June 12, 2011, 05:08:29 PM »
Best addressed on the ZX/ZZR forum.
http://www.zxforums.com/forums
Veteran USN '70-'76
