February 02, 2026, 06:17:31 PM *
Author Topic: Hoppy trailer converter inquiry  (Read 3269 times)
Hollyday
« on: June 17, 2011, 09:57:20 PM »
I know there was once a post on the various Hoppy trailer converters but I can't find that thing anywhere.
What's the best Hoppy trailer converter for an LED lighted trailer?
For a non-LED?
Powered and unpowered options.
Thank you!
PhredValk
Edmonton, Alberta, Canada
« Reply #1 on: June 17, 2011, 10:11:23 PM »
Search on the Home page for Hoppy trailer, you'll get lots of hist like this;
http://www.valkyrieforum.com/bbs/index.php/topic,21535.0.html
The company is actually Hopnel. There are two, one makes trailer electronics, one makes bike accessories.
Fred.
VRCCDS0237
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #2 on: June 19, 2011, 11:03:53 AM »
Fred.
Uhhhmm...no. The company is actually Hopkins. Hopnel makes great tank bibs.
I had the Hoppy 46255 version, with LED taillights. It lasted all of 2 hours! When I called Hopkins, I was informed that they are having problems with that converter, with LED's, and he sent me the 46365, which is called "short proof". Seems there's something fishy with the other converter, that just doesn't play nicely with the LED's. He couldn't tell me why, just that they've seen quite a few of them go south. He knew right off that I had LED's, even before I told him. I guess quite a few motorcyclists are going with LED tailights, I assume to cut down on current draw. Of course, the 46365 is a bit more expensive! You definitely want the power converter, as it uses the battery for it's power, not the existing wiring. Basically the same as putting relays in for all the lights. I haven't had any problems at all, since changing over to the 46365.
Here's the link to the 46365:
Hoppy 46365 Converter
And, Hopkins main webpage:
Hopkins Towing Solutions
Good luck - you'll love it!
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
Mr Steve
Feeding Hills, MA
« Reply #3 on: June 19, 2011, 09:21:00 PM »
I used a no name 3 - 2 wire converter, unpowered.  Works fine, but I did replace the turn signal relay to keep the flash rate even.
PhredValk
« Reply #4 on: June 20, 2011, 06:39:03 AM »
My bad, sorry. Typing without checking my facts.
Fred.
VRCCDS0237
Hollyday
« Reply #5 on: June 22, 2011, 06:00:27 PM »
Thank you for the info!   Very helpful!
Hollyday    Smiley
