September 17, 2025, 04:29:49 AM *
Author Topic: Went to an indoor range today and fired my shotgun.  (Read 1006 times)
« on: June 20, 2011, 12:28:12 PM »
Used these
12 Gauge - Winchester PDX-1 - Shotgun Ammo Testpowered by Aeva
Pretty darn good at 20 yards.
9Ball
« Reply #1 on: June 20, 2011, 01:28:21 PM »
I use those in my Taurus Judge...obviously only .410 though but they perform nicely on paper.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
YoungPUP
Valparaiso, In
« Reply #2 on: June 20, 2011, 05:56:51 PM »
I've got a local reloader that makes 12ga  home defense rounds that are just as nasty.  3  00 buck a 50cal ball and 3 more 00 buck.
99 STD (Under construction)
musclehead
inverness fl
« Reply #3 on: June 20, 2011, 06:10:37 PM »
there was a cautionary post about using reloads for home defense, something about "excessive" force or some such.  the folks in the know sohuld pipe up now.....
FryeVRCCDS0067
Brazil, IN
« Reply #4 on: June 20, 2011, 06:39:38 PM »
I've seen gun mags discourage the use of reloads for defensive use because of potential lawsuits from criminals saying "your bullets shoot too hard" Grin
Most of my home defense loads are my reloads in spite of that. As long as I can resist the urge to extract the bullet with a pocket knife to check it's performance I think (hope) I'll be OK on that one.
YoungPUP
Valparaiso, In
« Reply #5 on: June 21, 2011, 05:53:33 PM »
I hope I NEVER have to find out, but I do believe that deceased robbers don't talk
sugerbear
wentzville mo
« Reply #6 on: June 21, 2011, 06:07:00 PM »
but, their families do.
guns and ammo, i think, had the article about handloads in court. something like "overkill"
people have gotten in trouble for using 44 mags, 50 cal, etc
thought i quoted the article a while back, i'll see if i can find it.
BigAl
« Reply #7 on: June 21, 2011, 06:15:44 PM »
Slugs are good, in my 12 gauge Mossberg 500 18 1/2 inch factory barrel.
2 and 3/4 inch Double '00' are better.
But 3 inch double 00 are just going to kill about anything you point and shoot at.
Ultimate home defense weapon.
But my 9mm ain't bad with the stuff I put in it, Corbon Factory, Copper only, +P, one should do it.
Al
bscrive
Ottawa, Ontario
« Reply #8 on: June 21, 2011, 06:24:36 PM »
Up here in Canada they frown on that kind of defence.  Up here the frakin criminals seem to have all the rights and the victim has none.  Thanks to years of liberal socialism.  If someone breaks into your home you should have the right to stop them anyway you need to.
Ferris Leets
Catskill Mountains, N.Y.
« Reply #9 on: June 21, 2011, 06:39:58 PM »
Try #4 buck.
musclehead
inverness fl
« Reply #10 on: June 21, 2011, 06:40:18 PM »
overkill? is there such a thing??
got glazer safety slugs in a .38 special, should avoid potential lawsuits.
musclehead
inverness fl
« Reply #11 on: June 21, 2011, 06:52:23 PM »
we always worry that our rights to self defense will erode to that level or below. castle law still holds for now.
I remember hearing a story about Peru where there is NO castle laws. they live in virtual prisons complete with tall walls and glass embedded at the top, or barb wire, or the richer residents have electric wires. they have tons of law enforcement, but you can't wear jewlery openly it will get snatched. if a 230 line backer breaks into your house and you are 85 years old and you defend yourself with a knife 3" longer then the one your oppenent has? you are screwed.....
