February 02, 2026, 06:17:21 PM
Audiovox Cruise Control
Topic: Audiovox Cruise Control (Read 1776 times)
Shakie NC
Beulaville NC.
June 21, 2011, 03:14:16 PM »
Not realy a new thread but, Q. I remimber some of the thread speeking of VSSS or VSS, not sure now. My Q. is! on the 1998 Valk does the Audiovox cruise control sense the speed from the wheel speed sensor or from the speedometer head wiring. I have had the unit for a long time but never installed it, Am thinking it time to do so. I have picked up some good info from thread by Mellowyellow's thread, for problums later on, if any one has any knowlage to share of what the differance is and if the 1998 can be done like that. any and all comments well come. T I A . Danny
Shakie NC
MP
North Dakota
Re: Audiovox Cruise Control
June 21, 2011, 04:18:56 PM »
Neither. There is no electronic output there, so it is hooked to a coil.
Actually, you are setting the rpm of the engine. You can shift to a lower gear, and reapply the cruise, and it will set the rpm the same in that gear, so you will be slower.
MP
"Ridin' with Cycho"
5_19
Dublin, Texas
June 21, 2011, 05:54:59 PM »
Here is the link in shoptalk with an good write-up.
http://www.valkyrieriders.com/shoptalk/cruise-control.htm
IBA # 45723
2009 BMW R1200 GSA
bscrive
Ottawa, Ontario
June 22, 2011, 06:13:37 AM »
I hooked one up to my IS about 7 years ago. Works pretty good for a vacuum type cruise. Not too great if you are running with others that have electronic cruise controls. The Audiovox variation in speed is much greater but I an too cheap to spend a grand on an electronic cruise for my valk.
designer
Columbus, Ohio
June 22, 2011, 06:20:59 AM »
Quote from: bscrive on June 22, 2011, 06:13:37 AM
II an too cheap to spend a grand on an electronic cruise for my valk.
+1
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
