February 02, 2026, 07:51:18 PM *
Author Topic: HOW'D IT DO THAT? (UPDATE)  (Read 2437 times)
« on: June 24, 2011, 06:43:46 PM »
I ran  my Valk through the gears briskly and power shifted to 5th when the tach passed 6000 at about 90, let off and got down to 75 at a steady pace.  When I slowed I noticed I had dropped a cylinder, so I ran it up and it evened out.  The rest of the day I dropped a cylinder every time rpm got down to 2500 rpm or so.  Sounds like a slow speed jet is clogged.  How does a power shift at 90 cause a clogged slow jet?   Shocked  ???  Hoser
Found it, cracked vacumn plug on # 5 carb  Much thanks for all your advise.  I'll do my happy dance now.   Hoser   Smiley
Dr Hook You make my pants want to get up and dancepowered by Aeva
« Last Edit: June 26, 2011, 01:35:56 PM by Hoser » Logged
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: June 24, 2011, 06:47:51 PM »
May have broken some crud in the carb bowl loose and sucked it in.
Marty
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #2 on: June 24, 2011, 06:56:51 PM »
I'd say keep it above 90 mph and you'll be alright.
Save a horse, ride a Valkyrie
fordmano
San Jose, CA.
« Reply #3 on: June 24, 2011, 11:05:55 PM »
I am with you Fudd.... cooldude Evil
I would agree probably just some crud clogged it up probably got knocked loose with all that G-Force.
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
« Reply #4 on: June 25, 2011, 07:34:17 AM »
Well, I reckon I'll just treat it as that, and dump in some seafoam and techron for a while.  BTW, replaced the spark plugs, since I had about 40K on them, it is the # 3 cylinder according to the old plugs.    Hoser  ???  Undecided
« Last Edit: June 25, 2011, 07:37:33 AM by Hoser » Logged
« Reply #5 on: June 25, 2011, 10:54:12 AM »
I'd suggest dropping that float bowl to check for more of the same junk you suspect is causing the problem.
« Reply #6 on: June 25, 2011, 12:59:42 PM »
If it does'nt clear up in a day or two, I will.  Hoser
Earl in Pensacola
« Reply #7 on: June 25, 2011, 10:46:51 PM »
In-as-much-as the last thing you did was to change the plugs, pull and check them first!  Then, if nothing is found to be amiss, check into the carbs.
fordmano
San Jose, CA.
« Reply #8 on: June 26, 2011, 12:05:29 AM »
Oh! #3 is way so much fun to pull while the rack is in place,,, been there I am sure everyone remembers that little nightmare of mine.
Maybe just try opening the drain and catch what comes out so you can inspect it first.
83GS550
93XR650L TARD!
97WR250
01YZ125(x2)
05DRZ-125
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #9 on: June 26, 2011, 03:42:03 AM »
I was never a believer in that injection cleaner stuff but I bought a bottle of Lucas and poured 3/4 of it in my tank last week during fillup and it took care of a slight miss I was feeling.
« Reply #10 on: June 26, 2011, 01:36:30 PM »
Bump
« Reply #11 on: June 26, 2011, 02:23:25 PM »
"Maybe just try opening the drain and catch what comes out so you can inspect it first."
Yeah, fordmano is correct:
It would be the best thing at first, removing the bowl may/might be the second task.
I might add that removing the bowl can be problematic for the uninitiated. Not for the weak heart!
