February 02, 2026, 09:29:57 PM *
Author Topic: Dan Marc fuel solenoid (UPDATE)  (Read 3065 times)
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« on: June 25, 2011, 11:29:16 AM »
Has anyone ever had one fail ?
« Last Edit: July 10, 2011, 05:32:14 PM by Gear Jammer » Logged
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #1 on: June 25, 2011, 05:04:30 PM »
It makes me feel better that no one has answered you.  Maybe that's a good sign.  I keep a length of 5/16th" hose in the bottom of my bag "just in case"  It will fit good on the "T splitter" but be a little loose on the Pingle end.
Save a horse, ride a Valkyrie
3W-lonerider
Shippensburg Pa
« Reply #2 on: June 25, 2011, 06:41:39 PM »
iv'e been working on equipment for over 10 years..all of our equipment has electric fuel shutoff valves..in that 10 years the only electric valve iv'e ever had to replace was for L.P. gas. it got totally clogged shut..as far as regular gas..we have equipment that is at least 30 years old..still running the original electric valve it came from the factory with..
Gear Jammer
Magnolia, Texas
« Reply #3 on: June 25, 2011, 07:16:06 PM »
That's pretty much what I would have expected too.  Undecided   I'm not completely sure yet, but after running a 5/16  hose from the petcock to the T at the carbs, it now starts and runs.  ???  Solenoid shows power to the hot wire and the ground is good as well.  crazy2   I'm taking it off tomorrow to check it out. I'll get back to ya   Cheesy
3W-lonerider
Shippensburg Pa
« Reply #4 on: June 26, 2011, 04:14:53 AM »
it could be bad..anything is possible. basically all the electric valve is,, is a coil holding a plunger open..coils can short out.
valkyriemc
NE Florida
« Reply #5 on: June 26, 2011, 05:00:14 AM »
"Short" = momentary high current flow = fuse blows.    An "open" coil ? - no current flows, coil doesn't energize, and the valve doesn't open.
« Last Edit: June 26, 2011, 05:31:24 PM by valkyriemc » Logged
Veteran USN '70-'76
Gear Jammer
Magnolia, Texas
« Reply #6 on: June 26, 2011, 04:54:36 PM »
Solenoid seems to be functioning.  Now to figger out why it seemed to be starving for fuel  crazy2  And yes, the petcock was turned "ON",,,  Roll Eyes   uglystupid2
5_19
Dublin, Texas
« Reply #7 on: June 27, 2011, 10:39:28 AM »
Bobby I am using 2 DanMarc fuel without the filters valves. Screen are still on the regular fuel valve that mounted on the tank. If I remember correctly you are also using a gravity flow extra fuel tank that is higher than the stock tank. The reason for 2 fuel cut-off solenoids, with the ignition off both valves are closed! Ignition on; only 1 valve open at the time, valve 1 open ..valve 2 closed and visaversa. This way I can never fill up the highest tank and overflow the lowest if I forget to close either valve. All you need 1 on-off switch and a double throw 12VDC relay. Supply power to the switch and relay only with the ignition on. NC contact to valve 1 and NO to valve 2.
IBA # 45723
2009 BMW R1200 GSA
Gear Jammer
Magnolia, Texas
« Reply #8 on: June 27, 2011, 05:43:55 PM »
Thanks TJ,,, I'll keep this in mind.  First I have to determine the cause of the engine dying while idling the other day. Then it wouldn't start again.  I've got another Solenoid coming in a couple of days.
Gear Jammer
Magnolia, Texas
« Reply #9 on: July 10, 2011, 05:30:45 PM »
After not finding a problem with the Dan Marc solenoid, I started eliminating other potential faults.  I didn't find anything wrong.  ???   Petcock checked out too.  Undecided   I replaced all the fuel hoses in case there was one collapsing.  I still don't know what was wrong, but it starts and runs now.   Smiley   I'm pleased to see this, but I'd like it better if I had identified the cause of it dying and not restarting previously.  I'd hate to see it do it again while I'm out riding far from home, instead of on the driveway as before.  I guess it could be worse.  crazy2
