February 02, 2026, 06:11:26 PM *
Author Topic: Bushings are...  (Read 2005 times)
The Anvil
Derry, NH
« on: June 27, 2011, 01:56:20 PM »
...BUSHED. I read recently where they're an issue on the Valk (something I didn't know till I saw it here by chance) so today when I pulled her out for a ride I gave it a good looking over and immediately noticed the telltale misalignment of the shock eye with the bolt. I can also see some squeeshed rubber poking out. Totally hosed.  Undecided
I just ordered a set of Gary's bushings. I'll post pics if they come out looking particularly gnarly (and I think they might) because I don't know if they've ever been replaced.
« Reply #1 on: June 27, 2011, 05:11:35 PM »
Did you just buy one set or two? (1 set = 2 bushings, one for each side).
The recommendation is to replace only the warn one, which is usually the top. I was going to replace them both (2 sets), and was wondering if the better bushing makes the ride a little firmer or loose?
The Anvil
Derry, NH
« Reply #2 on: June 27, 2011, 05:13:32 PM »
I ordered two sets. I'll look at the bottoms and if they look good I'll leave em (maybe) but they're only 15 bucks a set so I might just say screw it and replace all 4 at the same time.
madmaxinde
Trier, Germany
« Reply #3 on: June 28, 2011, 09:23:46 AM »
I replaced both sets, top and bottom about a month ago, and it was a very noticeable improvement in the corners. That squishy (only way to describe it) feeling in the corners is totally gone, especially when riding 2up
Keep the shiny side up Bro
VRCC # 33008
The Anvil
Derry, NH
« Reply #4 on: June 28, 2011, 09:29:15 AM »
I have been noticing a bit of "inaccuracy" or a tendency to not hold lines in corners as well as It did before. Could very well be that.
The Anvil
Derry, NH
« Reply #5 on: July 01, 2011, 08:44:19 AM »
I replaced em this morning. Took a 1/2 hour. The lowers didn't look too bad but they were dried out badly so I replaced them. The uppers were TOAST. One (right side) was so worn that the lower portion where it's squeezed between the shock eye and mount was clean through.
« Reply #6 on: July 01, 2011, 01:56:13 PM »
get the urethane ones, they last longer.
http://www.rattlebars.com/cart/bushings.html
The Anvil
Derry, NH
« Reply #7 on: July 01, 2011, 02:55:58 PM »
I did  cooldude
I took it for a ride a little while ago. Big improvement. Gary ships quick too.
