February 02, 2026, 07:44:27 PM *
Author Topic: Question re: Küryakyn 4050 highway pegs  (Read 2823 times)
lilzaphod
Iowa City IA
« on: June 29, 2011, 04:32:02 PM »
I have a question regarding the 4050 peg set for those of you who have them.
I was trying to follow the instructions to put the tiny little roll pins into the mounting for the actual footrest, and I lost one of those little buggers trying to get it in the hole that is too small. And I don't feel that 'drilling' the hole out of a new part is a good answer.  (It's a fast way to drill through my hand).
I've had dually pegs before on a different ride, and I never had those little pins, the hooked straight up into the clamp.  Are these critical, or are they just there as a safety nuisance as determined by some lawyer so that the peg doesn't end up coming loose and angling down and they get sued when someone corners too hard and high-sides?
I'm not that mechanically inclined, but these really look like a solution for a problem that doesn't exist if you keep the bolts tight.
Thanks.
ptgb
Youngstown, OH
« Reply #1 on: June 29, 2011, 06:08:13 PM »
I have mounted about 3 sets on various Valks. What I found to work the best is hold it above the hole with a needle nose plier. Squeeze the roll pin and I tap it in with a small tack hammer.
Didn't have to drill any.
lilzaphod
Iowa City IA
« Reply #2 on: June 29, 2011, 06:10:11 PM »
Thank you for the reply.  Since I dropped/lost one, and since these appear to be superfluous, would I be making a huge mistake by not using them?
I appreciate your opinion on this, and I do not hold you liable if the world ends by my leaving them out.  Smiley
« Last Edit: June 29, 2011, 06:12:09 PM by lilzaphod » Logged
ptgb
Youngstown, OH
« Reply #3 on: June 29, 2011, 06:12:51 PM »
I would use them... should be able to get a replacement at the hardware store.
lilzaphod
Iowa City IA
« Reply #4 on: June 29, 2011, 06:18:02 PM »
Ok, I'll get a new one (or a few for spare) and suffer through getting them installed with my hamfists.
I need to get a bigger Allen Wrench for the swing arm bolts anyway.  I thought Kury was a metric company, but it appears they are standard, and my 10mm is just a touch too big.
ptgb
Youngstown, OH
« Reply #5 on: June 29, 2011, 06:20:36 PM »
Got no idea what size the Allen is... I lucked out and had a big one in the drawer that fit.
snohunter
rochester mn
« Reply #6 on: June 30, 2011, 09:27:23 AM »
just did them on mine i i think the large hex is 3/8
T.P.
Apple Valley, Minnesota.
« Reply #7 on: June 30, 2011, 07:07:30 PM »
What PTGB says...............Put the drill down!   T.P.
currahee2-6
RIDIN THE DRAGON'S TAIL IN NOVEMBER!
Margate, Florida
« Reply #8 on: June 30, 2011, 11:13:40 PM »
you should be able to find roll pins all day long in almost any size in the specialty drawers at Lowes, Home Depot or ACE.  Cool
to those who fight for it, Life has a flavor the protected never know.
Farther
Quimper Peninsula, WA
« Reply #9 on: July 01, 2011, 09:06:40 AM »
I recall having some problems with the pins too.  If memory serves me, I think I used a pair of large slip joint water pump pliers to press them into the hole.  Line up the pin using needle nose pliers and press them in.
~Farther
lilzaphod
Iowa City IA
« Reply #10 on: July 03, 2011, 04:57:45 AM »
This were impossible to find - lowes, Menards, Ace, didn't have them small enough.  Ended up tearing apart the garage to find the one I dropped.
Sodbuster
« Reply #11 on: July 03, 2011, 06:36:35 AM »
I'd be willing to bet that if you contacted Kuryakyn customer service they would be willing to send you one free of charge.
http://www.kuryakyn.com/Customer-Service.aspx
VRCC # 30938
Steve K (IA)
Cedar Rapids, Iowa
« Reply #12 on: July 03, 2011, 02:34:12 PM »
I think this has been answered...the hole for a roll pin will always be smaller diameter than the pin.  Second, I have found Kuryakyn products will have both metric and SAE screws/bolts.  That is why I carry a set of both style allen wrenches.
States I Have Ridden In
