March 25, 2026, 02:08:42 AM *
Author Topic: Anybody on the dark side running a P195r60 or 65R16?  (Read 1284 times)
« on: June 29, 2011, 05:04:47 PM »
If so, what brand and how do you like it?  TIA
art
Grants Pass,Or
Grants Pass,Or
« Reply #1 on: June 29, 2011, 05:49:57 PM »
I'm running a DURO performance 195-55.I have never heard of it before but I got it at a tire dealer in so.cal.for $75.This is my second one an the last had 25000 miles on it when I changed it.I like the 195 because there is less bump stear .I run about 35psi an It handles great up to 125 mph.Have not gon above that but am sure I could with no problem.This is my fourth car tire an now I am also on my second darkside front.I'll never go back.Got 12000 out of the rear tire on the front.Normal in 7-8000 miles.I also mount my own in the garage with tire irons by hand
bscrive
Ottawa, Ontario
« Reply #2 on: June 29, 2011, 05:53:52 PM »
Have you ever pulled a trailer with them, if so, how is the cornering?  I am thinking of going to a car tire but I sometimes like to corner hard and I worry about the back loosing grip.
Fla. Jim
« Reply #3 on: June 29, 2011, 06:07:28 PM »
I've been running the  Michelin 205-65-16 hydroedge @ 26 lbs for about two yrs and twenty thousand miles now. And love it. Never pulled a trailer. It did take about a thousand miles to break in. I did start off at 40 lbs of preasure and did not like it nearly as well as at the lower setting . I am at 240lbs and it is on a 97 tourer. Also did the nut-cage mod and spread the fenders while I had the tire off. Rides better than I ever imagened it would and it sticks like glue. Also have 7/32nds of tread left. comes with 10/32nds I believe. I am not known for getting great milage the original 206 from Honda lasted a whole 5k
X Ring
VRCC #27389, VRCCDS #204
« Reply #4 on: June 29, 2011, 06:54:21 PM »
I'm running a Toyo Proxes TPT in 205/65HR-16 on my '97 Tourer.  I like it but when it comes time to replace it I will have to find another tire.  Toyo discontinued it.  All I did was the nut cage mod and I think I could get away without it.  I have 8-10mm clearance between the swingarm and sidewall.
Marty
Disco
Republic of Texas
« Reply #5 on: June 29, 2011, 08:53:42 PM »
I'm running a Continental Vanco in 195/65-16.  It's not quite as neutral as the 175/70-16 Dunlop Winter Tread ROF I had on the GL1800, but, to me, and despite the fact that it is not symmetrically siped, it has much less "personality" than the rather square GYTT I've ridden (friend's bike - not mine).  I run it at 40psi cold.  Anything under 36 or so and it starts to feel a bit squishy when pushed in the corners.  I put it on last June with 3oz of Dyna Beads, it has 17,2XX on it, and looks like it will go another 15,000.  It has served me well and never made me feel compromised, whether on the Tail of the Dragon, doing 600 miles fully loaded in the rain, or on my Iron Butt SS1000 last July.
Too bad it's discontinued and Dunlop doesn't make a Valk-sized Winter Tread ROF...
If I had to replace it today, I'd probably go General Altimax in 205/60-16.
BTW, 195 requires no nut-cage or washer mod, and the 65 series is practically the same overall diameter as the stock tire, so your RPMs don't increase per MPH.  Too bad there are so few options out there.
« Last Edit: June 29, 2011, 08:57:54 PM by Disco » Logged
22 CRF450RL, 19 BMW R1250RT
78 CB550K, 07 Helix
71 MT50 Trailhopper
rodeo1
« Reply #6 on: June 29, 2011, 09:35:27 PM »
i run 255-60/zr16
Tropic traveler
Silver Springs, Florida
« Reply #7 on: June 30, 2011, 02:20:48 AM »
Still looking for a 195/70/16 to put on the Valk.
So far no luck.  Angry
'13 F6B red for Kim
« Reply #8 on: June 30, 2011, 05:05:31 AM »
I found some 195/65r16's but they seem to only be available in the UK.  I believe this is a minivan size.  Haven't found any in the US in that size.  Currently running 205/60r16's on both my bikes, but would like to go narrower and taller for lest bump steer.
