scarylarry
« on: July 01, 2011, 11:11:43 AM » |
hi all...have a 97 standard...noticed the oil temp light isn't coming on anymore...was hoping someone out there has some experience w/ this problem and could give me some suggestions...thanx in advance....larry
Jess Tolbirt
« Reply #1 on: July 01, 2011, 11:17:26 AM » |
there is not an oil temp light on the bike,, there is an oil pressure light... take the wire off the oil pressure thingy on the motor and ground it,, if the light comes on then replace the oil pressure sending unit,, if it doesnt come on then there are other problems,,
Valkyrie member # 23084 Started out on old forum on day one but lost my member number.
« Reply #2 on: July 01, 2011, 11:19:28 AM » |
Is is temp or a pressure indicator....anyways, if you mean its not coming on with the ignition.....the oil light and the side stand light should light up as soon as you turn the key. Maybe the bulb is blown.
« Reply #3 on: July 01, 2011, 12:17:44 PM » |
I believe y'all are talking about the light that doesn't come on on either my Red and White nor Wimp's Red and White... I'm glad to know they really are supposed to work... My meter lights work so poorly in general that I can't see jack about my speed or anything when it is after dark... -Mike
Daniel Meyer
The State of confusion.
« Reply #4 on: July 01, 2011, 12:50:46 PM » |
Need to be clear which light you are talking about on the standard. The temp light does not come on with the key. It only comes on if you overheat. The sidestand and oil pressure DO come on with the key (assuming the sidestand is down).
CUAgain, Daniel Meyer
Ferris Leets
« Reply #5 on: July 01, 2011, 01:13:12 PM » |
Sidestand down light? Did not know there was such a thing. Not on the IS anyway.
Ferris Leets
« Reply #6 on: July 01, 2011, 06:10:49 PM » |
I thought so but I checked. The water temp light comes on when the switch is turned on.
scarylarry
« Reply #7 on: July 02, 2011, 01:34:37 AM » |
ok...green light far left, red,,,yellow... greenshows a temp gauge...why I thought oil temp...red ..in middle..shows oil can..oil pressure?...yellow sidestand down
scarylarry
« Reply #8 on: July 02, 2011, 01:42:52 AM » |
Dan...thought all 3 came on...actually they did...but, you're saying if it gets hot ,,that green light under the thermometer symbol Will light up again?
scarylarry
« Reply #9 on: July 02, 2011, 01:45:36 AM » |
totally know what u r saying about not seeing instruments @ nite...change em all out mostly
scarylarry
« Reply #10 on: July 02, 2011, 01:59:24 AM » |
now that I think about it...really poundin the piss out of it...this bike can do it all...including frying you're shins
« Reply #11 on: July 02, 2011, 04:03:20 AM » |
On a standard/tour. The light to the far left. (water temp) can only come on if the water temp is too high. It doesnt come on with the ignition, so if that is the "problem" its now fixed
« Reply #12 on: July 02, 2011, 06:25:52 AM » |
Yep, like some of the fellas say, the far left light[ coolant temp] does not come until the engine is too hot.. Regarding the instrument lights, the standard lights are about 2 watts.. Replacements can be:: #158, 3.3W #161, 2.7W #194, 3.8W #168, 4.9W [some have had the chrome blister from too much heat]
