August 23, 2025, 07:18:38 AM *
Author Topic: Carb parts  (Read 1970 times)
« on: July 06, 2011, 02:58:56 PM »
Can anyone furnish me with a part number for the rubber diahfram insidethe top cover of a carburater. I cannot  identify it by looking at the parts fiche.  Hoser
9Ball
« Reply #1 on: July 06, 2011, 03:05:28 PM »
#18, only $72 each
http://www.hdlparts.com/fiche_section_detail.asp?section=148147&category=MOTORCYCLES&make=HONDA&year=1999&fveh=3467
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #2 on: July 06, 2011, 06:09:52 PM »
Update on my request, I no longer need that item, anybody else taken the top off a carb and found this?  I even have some spares, and I fixed it!  Thanks for finding the diaphram though.   cooldude  Hoser
« Last Edit: July 06, 2011, 07:58:05 PM by Hoser » Logged
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #3 on: July 06, 2011, 09:45:32 PM »
hoser....yes i've found it, and then i changed them all over to the interstate variety.
9Ball
« Reply #4 on: July 07, 2011, 12:24:29 AM »
yep, seen it before.
You must be twisting the throttle way too hard.... Grin
Metal fatigue is the only explanation.  Someone may have kinked it a bit during re-install and it failed at that point.  A bit cheaper fix.
As far as the diaphrams, I'm glad I picked up a spare set of carbs quite a few years ago.  Paid what 2 diaphragms now cost for everything, $150.
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #5 on: July 07, 2011, 04:57:43 AM »
I had IS springs in it, too many power shifts at redline, I assume.  Very happy to get out of it for cheap.  In fact I think it's time for my happy dance.   Cheesy  Hoser
Dr Hook You make my pants want to get up and dancepowered by Aeva
ValkFlyer
Antioch, CA
« Reply #6 on: July 08, 2011, 01:49:04 AM »
Whoa, hold on there partner ..........
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #7 on: July 08, 2011, 04:17:47 AM »
Hoser,
  Is that the cause of your problems? If that's it, and you didn't tare into those carbs yet, I'd for sure be doing the happy dance cooldude
  It should run like a scalded dog now, I'm sure those carbs are cleaner with the cocktails you've run through them.
-Doug
« Reply #8 on: July 08, 2011, 06:23:09 AM »
All is good!  Hoser  Smiley
