August 23, 2025, 07:18:56 AM *
Author Topic: Start switch safegard  (Read 1170 times)
JetDriver
Columbus, OH
« on: July 06, 2011, 08:51:55 PM »
http://www.rattlebars.com/mtz/startrelief.gif
Chet has a diagram for unloading the start switch.  The blue/white wire from the dimmer switch hooks up to the relay post 87, and the blue/white wire from the starter hooks up to the trigger 86.  In the headlight shell, how do you tell what end of the blue/white wire is what?
Valkpilot
What does the data say?
Corinth, Texas
« Reply #1 on: July 06, 2011, 08:59:27 PM »
Unplug the blue/white wire at the bullet connector in the headlight shell.  Use a volt meter with the key on.  With the red probe on the bullet and the black probe touching ground (the inside of the shell should do, or stick it in one of the green connectors) check each side of the bullet connector.  The side that shows 12 V is the side that comes from the start switch.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
JetDriver
Columbus, OH
« Reply #2 on: July 07, 2011, 08:05:30 AM »
Thanks Valkpilot.  I needed the explanation to be that simple- seriously!  Smiley
