August 23, 2025, 07:20:44 AM
Vacuum leak(continued from previous post).
Topic: Vacuum leak(continued from previous post). (Read 1585 times)
Raverez
No good deed goes unpunished
Central New York State
July 07, 2011, 11:18:51 AM »
So, the hsst noise is a vacuum leak. The left side middle cylinder hose has a crack in it. Now I have the tank removed and am going to to remove the airbox to get to the hoses. What should I be looking for so that I don't break anything I can't fix? next, what size hose do I need? I'm thinking get a spool of hose and replace all the lines.
Thanks all, Raul
Bobbo
Saint Charles, MO
Re: Vacuum leak(continued from previous post).
July 07, 2011, 11:22:03 AM »
You can do it without removing the tank and airbox:
http://www.valkyrieriders.com/shoptalk/AirBox%20VentHose/venthose.htm
This short tutorial shows some of the techniques I used to change out the hoses by tying a string to each one. This shows the airbox off, but it can be done without removing it.
Last Edit: July 07, 2011, 11:25:57 AM by Bobbo
Raverez
July 07, 2011, 11:27:52 AM »
Thanks Bobbo. I'll see if I can do it that way. What size is the vent hose? Would it be available at a local Autozone?
Bobbo
Saint Charles, MO
July 07, 2011, 11:34:19 AM »
5/32 hose was used for this example. It stays on without needing a clip. Most auto stores will have it.
=> InZane XXV
