February 02, 2026, 09:30:13 PM *
Author Topic: torque value?  (Read 1705 times)
bg
Cumming, Ga
« on: July 09, 2011, 12:07:05 PM »
just noticed today the 2 front bolts (6-32) that hold the front fender on are missing.
i have an 00 I/S and had been noticing a rattle. thought it was the faring being loose, but it was
the fender bouncing up against the front forks.
i picked up 2 bolts at the honda dealer but they didn't have the torque values.
anyone know what that value would be?
i put them in and tightened them up and , viola, the rattle stopped.
now i just want to make sure they are tight enough and don't vibrate out again.
« Reply #1 on: July 09, 2011, 12:13:18 PM »
Not every bolt on the bike has to be scientifically torqued or it will explode.....youre fine how it is
B
Capital Area - Michigan
« Reply #2 on: July 09, 2011, 12:16:12 PM »
Good to hear ... I skipped A LOT of science class.  2funny
« Last Edit: July 09, 2011, 01:57:59 PM by B » Logged
« Reply #3 on: July 09, 2011, 12:16:41 PM »
I don't think I'd stick a torque wrench on a 6-32 fastener.  If it doesn't break, its tight enough.. If you don't it come back out, you could add some lock-tite..
bg
Cumming, Ga
« Reply #4 on: July 09, 2011, 01:45:45 PM »
mucho grassyass guys.
i'll snug it up nice and tight and keep an eye on it.
Madmike
Campbell River BC, Canada
« Reply #5 on: July 10, 2011, 12:46:08 AM »
green loctite for set screws etc. meant to retain not lock...
Ferris Leets
Catskill Mountains, N.Y.
« Reply #6 on: July 10, 2011, 06:47:33 AM »
6-32?  Where?
9Ball
« Reply #7 on: July 10, 2011, 06:55:56 AM »
6-32?  Where?
he has the nomenclature wrong, they are actually 6 x 32 (6mm x 32 mm long)
generic torque spec for a 6 mm bolt is 7 lbf-ft
« Last Edit: July 10, 2011, 06:57:39 AM by jrhorton » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
F6Dave
« Reply #8 on: July 10, 2011, 08:57:13 AM »
There's not much vibration there, so it's hard to imagine those bolts getting loose unless the nuts were only finger-tight.  Maybe someone had the fender off for a fork seal change or something, and hand-tightened everything during reassembly, but forgot to use a wrench later.  I did that once with the muffler bracket nuts when I changed a tire.  Lost one of the four.  Like others said, I wouldn't worry about the torque value on a bolt that small.
