February 02, 2026, 11:09:33 PM *
Author Topic: broken kickstand bolt  (Read 1785 times)
deadvelvet
Owensboro,KY
« on: July 24, 2011, 08:12:40 AM »
is there some kind of trick to get the tip of the broken bolt out cant seem to get it
fantsybikr
O HI O
« Reply #1 on: July 24, 2011, 09:01:21 AM »
tool called an ez out..use it by drilling a smaller hole into broken bolt then inserting ezout tool by tapping lightly with hammer and then use a adjustable wrench to turn ezout in left hand direction to hopefully remove broken bolt.. the trick is to try to drill hole as close to center of bolt as possible..a little heat helps...but use at your our risk
VRCCDS 0252
  VRCC   26284
 GWRRA 329832
« Reply #2 on: July 24, 2011, 09:19:00 AM »
If you're talking about the kickstand spring bolt there is no problem.
You will find a jam nut on the backside that when you loosen it, the broken remaining part will easily screw out.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: July 24, 2011, 09:31:36 AM »
Refer to this fische: http://www.hdlparts.com/fiche_section_detail.asp?section=148120&category=MOTORCYCLES&make=HONDA&year=1998&fveh=3466
The nut to which Ricky-D refers is #19 on the parts diagram.  It's easy to miss that it is the retention nut for the kickstand spring "hook" bolt (#11 on the diagram) since is also has the hose holder (#12) attached.
Note: the bolt end may or may not unscrew when you take the nut off.  Either way, it's easy to separate it from whichever part it stays in by grabbing and turning it with small vice grips, channel locks, or pliers.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Mr.BubblesVRCCDS0008
« Reply #4 on: July 24, 2011, 03:16:02 PM »
I had to drop my stand off the bike to get the back nut loose. After that the broken piece screwed out with just my fingers.
Raverez
No good deed goes unpunished
Central New York State
« Reply #5 on: July 24, 2011, 07:02:20 PM »
Going back to the microfiche, is # 11 the bolt that broke?
Valkpilot
Corinth, Texas
« Reply #6 on: July 24, 2011, 07:05:09 PM »
Good point.  We all assumed it was, since it is the usual culprit.
What about it, deadvelvet?  Did we assume incorrectly?
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
