February 02, 2026, 11:09:38 PM
Ultimate Lowrider seat fit question
Topic: Ultimate Lowrider seat fit question (Read 1810 times)
Magellon
Santa Rosa, CA
July 24, 2011, 10:34:14 AM »
Will a Ultimate Lowrider from a Interstate fit on a Standard? Looking at buying a used one that has been test fitted on a Tourer for size and seems to fit just fine. Anyone else done this?
If so any pros or cons? Thanks in advance for the reply.
Last Edit: July 24, 2011, 10:36:47 AM by Magellon
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
Re: Ultimate Lowrider seat fit question
July 24, 2011, 12:08:22 PM »
the only issue I've heard is there may be a bit of a gap between the tank and the seat. The IS tank is larger/longer than the Tourer/Std tank, so the IS seat is a little shorter on the nose. Other than that, you're good to go I think
X Ring
VRCC #27389, VRCCDS #204
July 24, 2011, 04:57:31 PM »
You know the old saying, a picture is worth a thousand words. Well, here's two thousand words.
Marty
JimC
SE Wisconsin
July 24, 2011, 08:08:13 PM »
The interstate tank is the same length as the standard and tourer, the only difference is that it is higher at the tail end.
If you look at the picture above, the one with the red band around the bottom, the interstate tank would be higher in that area by a couple of inches so they make the front of the seat more flexible to ride up on the tank.
I have a factory seat on my bike ( a standard ) with an interstate tank, and it fits just fine.
Jim
Jim Callaghan SE Wisconsin
X Ring
July 24, 2011, 08:27:30 PM »
Quote from: Pluggy on July 24, 2011, 07:30:57 PM
Looks nice. What does the rear end of Marty have to say? (1000 words not needed)
How bout my animated one?
What do you want to know?
Marty
Magellon
Santa Rosa, CA
July 24, 2011, 10:05:05 PM »
THANK YOU MARTY for the pic of the seat. Don't quite have a 1000 words but it looks good to me. And thanks to Jim C for the explanation also makes total sense. Looking forward to a new seat.
Paul
