February 03, 2026, 12:40:36 AM *
Author Topic: rebuilding final drive  (Read 1942 times)
zimmerleemark
porter texas
« on: July 28, 2011, 02:36:54 PM »
trying to see if anyone has rebuilt their final drive? near as i can tell i need part 6 in finche
http://www.hdlparts.com/fiche_section_detail.asp?section=148039&category=MOTORCYCLES&make=HONDA&year=1997&fveh=3465
is there anything i should look for, and can bearings part 28 in finche be pressed out and new ones pressed in?
thank you,
mark
« Last Edit: July 28, 2011, 04:39:20 PM by zimmerleemark » Logged
lee
Northeast Tennessee
« Reply #1 on: July 28, 2011, 08:08:48 PM »
Just a few things you may or may not know:
 1. All the INTERNAL PARTS from a 1500 Goldwing final drive are the same as the Valk. final drive.
     Meaning: If you know where there is a good 1500 wing final drive you can use the ring gear and
     pinion from it.  The final drive HOUSINGS (wing and valk.) are not the same.
 2.  SHIMS: You may need both pinion shims and or ring gear shims.  #19 and #17
 3.  Unless you know exactly what you are doing, do not try to remove bearing #1.
      It can be done if you have Dental Tools in your tool box.
 4.  Replace the Ring Gear Seal.  #32
 5.  All the other bearings are no problem, two large screw drivers are all you need to remove them.
 6.  A better option would be E-Bay, Pinwall.
« Last Edit: July 28, 2011, 08:18:16 PM by lee » Logged
Time is not what is taken but what remains.
C. Drewry
keepinon
New Caney, Tx
« Reply #2 on: July 28, 2011, 08:27:48 PM »
Lee, his Valk is at my house. Just a few observations:
We attempted the swap of the ring gear & pinion, from the final drive of a '91 'wing.
1. The top of the gear teeth of the Valk drive was wider than the 'wing's. The tooth count on both the ring gear & pinion was the same, Valk to Wing.
2. The pilot (part of the shaft that inserts into bearing in the housing) of the Valk pinion shaft was .015 larger than the 'wing pilot.
I want to check the later models ( '97 up) to see if they are the same measurements, just don't have one available at the moment.
As always, open to all suggestions.
1998 GL1500 CT Trike
lee
Northeast Tennessee
« Reply #3 on: July 28, 2011, 08:57:58 PM »
I stand corrected.
Parts fiche  for 91 wing dosen't even show the pilot bearing.
The 97 does and has the same first 5 numbers (06910).
The change mite have started in 96.  Same first 5 numbers for ring gear and pinion (41310).
« Last Edit: July 28, 2011, 09:15:37 PM by lee » Logged
C. Drewry
Mr.BubblesVRCCDS0008
« Reply #4 on: July 30, 2011, 05:12:23 AM »
Dennis, I have a spare final drive with 16K miles on it if he wants to borrow it till you get him running you are welcome to borrow it. I hate to see anybody  without their ride. cooldude
keepinon
New Caney, Tx
« Reply #5 on: July 30, 2011, 07:25:45 PM »
Thanks Millard, but a kindly member had a spare from his trike job that we got this morning. MZ is back on the road.  Smiley
zimmerleemark
porter texas
« Reply #6 on: July 30, 2011, 09:07:34 PM »
yes i am thanke to "poor ole harry" nice gentleman, and dennis. thank everyone for your much needed help. bike rides soooo much smoother now Grin
mark
« Reply #7 on: July 31, 2011, 02:48:22 AM »
I know Harry. He lives just a couple miles from where I work. Glad to hear ya got the bike back on the road again.
