November 23, 2025, 12:26:48 PM
Kuryakn Ergo Boards on an I/S?
Topic: Kuryakn Ergo Boards on an I/S? (Read 1107 times)
dieselrambud
August 03, 2011, 01:15:47 PM »
Just like the title says, how can I do it. Couldn't figure it out with the last I/S I had but that was 6 years ago. Heard the Harley set up will work. I just want to run the ergo highway boards on the crash bars with as much adjustability as possible. Thanks
NITRO
Eau Claire, WI
Re: Kuryakn Ergo Boards on an I/S?
August 03, 2011, 02:11:10 PM »
Alph has them on his IS, he can help you out. I believe he cut a portion of the scoops off the underside of the highway bars to make them work.
When in doubt, ride.
dieselrambud
August 03, 2011, 05:46:24 PM »
So will the GL1800 set fit the lower crash bar? Any idea what diameter it is?
PhredValk
Edmonton, Alberta, Canada
August 03, 2011, 11:22:49 PM »
The strait parts are 1" diameter. If you want them on a curve you'll have to go a bit bigger and fill with tubing or leather.
Fred.
VRCCDS0237
=> InZane XXV
