February 03, 2026, 02:23:50 AM *
Author Topic: valve adjustment  (Read 1728 times)
rodeo1
« on: August 08, 2011, 02:10:54 PM »
how many have ever done a valve adjustment on your valk ? how many actually needed them adjusted ? how many miles till you needed one ?
« Reply #1 on: August 08, 2011, 02:15:56 PM »
Did it at  40000 and 80000, never did really need much adjustment.   cooldude  hoser
ValkFlyer
Antioch, CA
« Reply #2 on: August 08, 2011, 02:25:23 PM »
Current mileage 92K.  I've checked mine every 15K and have only made 2 minor adjustments.
redflash
Southern New Hampshire
« Reply #3 on: August 08, 2011, 03:51:38 PM »
did mine at 12K, 24K and 40K, I'm at 77k and thinkin about it again Smiley
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: August 08, 2011, 04:09:41 PM »
Checked mine at 125,000 and three of the twelve were out less than a thousandth. Other nine were exactly set.
rodeo1
« Reply #5 on: August 08, 2011, 04:42:14 PM »
mines at 31,000 guess ill wash it instead.
i had a pretty bad backfire on the right bank when under compression. tightened up the rubber intake tubes  and that stopped, so i guess its good for another 31,00
thanks guys
Pete
« Reply #6 on: August 08, 2011, 04:56:16 PM »
I check then as outlined in the service list.
Usually have to adjust some, although never very much.
tank_post142
south florida
« Reply #7 on: August 08, 2011, 05:33:52 PM »
every 100,000 or so. never been out more than .002-.003 on a couple.
I got a rock Sad
VRCCDS0246
six2go #152
Ft. Wayne, IN
« Reply #8 on: August 08, 2011, 07:25:31 PM »
Mine got checked/adjusted every 12,000 miles up to 72,000. Generally one or two needed tweaking to get in spec. I did the valves a few weeks ago @ 94,000 and loosened all the adjusters & reset each one. Why? Cuz I felt like it.  crazy2
