February 03, 2026, 02:23:53 AM *
Author Topic: REAR TIRE REMOVAL PRE OP QUESTION  (Read 1678 times)
currahee2-6
RIDIN THE DRAGON'S TAIL IN NOVEMBER!
Margate, Florida
« on: August 09, 2011, 06:22:43 PM »
Greetings!
I need to know if I will be able to remove the rear tire on my 2000 IS while it is up on a CENTER STAND? (I have a RIVCO CS) The CS lifts the rear wheel about 3 or 4 inches off the ground when deployed. I will be removing the rear fender (half) anyway for a tail light project (THANKS X_RING !)  cooldude and a spline/u-joint service call. I don't have a bike lift so I'm just making sure I can do what I want without one.
Thanks all in advance.
Dave
to those who fight for it, Life has a flavor the protected never know.
Daniel Meyer
The State of confusion.
« Reply #1 on: August 09, 2011, 06:27:35 PM »
Yes. You have to remove the rear fender segment as you stated, and the bag guard crossover if you have guards.
Pull the bags off the pans, pull the shocks, lift the swing-arm above the pipes to remove the axle (it will come out over the pans).
(should have come to Saturday tech session at Inzane! I'd have showed you!)  cooldude
CUAgain,
Daniel Meyer
bigfish_Oh
Allis
West Liberty,Ohio 43357
« Reply #2 on: August 09, 2011, 06:49:43 PM »
Daniel, I have one comment to add to your great tech session I found this morning.
   You mentioned that the dampers need no lube, it only collects dirt if greasy. As you say in your books that I am enjoying "remember this for later".   When you was removing the wheel, you said it will not come off without the star in the wheel. The SECOND reason to not lube the dampers is they will not stay in the wheel if slippery !!! I had to remove pumpkin and shaft with wheel.
Thanks to Daniel, I shoulld have this down next time.
What size is the allen in the axle? 7.5mm ?
2012 HD Road King Classic, Teq sunrise/HD Orange
2009 HD Nightster,orange
1974 CB550F,org
1999 Valkyrie,orange/Black (20K)
2009 GMC 3500 Duramax CC Dually 4wd (new)
1957 WD45 Allis Chalmers Grandpa bought new
1982 CBX (new)
1980 CBX (6K)
1979 CB750F (new)
1958 Lambretta TV175 (Dad's new)
4
Ferris Leets
Catskill Mountains, N.Y.
« Reply #3 on: August 09, 2011, 07:02:48 PM »
I just removed my rear tire. The plate stayed in the hub.  I don't know if it is supposed to be there but on the bottom of the rear end there was a slot.  I stuck a screw driver in and popped the plate out into the wheel.
Daniel Meyer
« Reply #4 on: August 09, 2011, 07:34:46 PM »
Not a half size. Pretty sure it's an 8.
Exactly what it's there for! Smiley
CUAgain,
Daniel Meyer
PhredValk
Edmonton, Alberta, Canada
« Reply #5 on: August 10, 2011, 02:41:32 AM »
It's an 8mm hex. Mine wouldn't work, but it looks like someone used a metalic hammer to set it at one time, and the 8mm won't work anymore. Out comes the Dremmel to rescue the rear end.
Fred.
VRCCDS0237
« Reply #6 on: August 10, 2011, 05:47:33 PM »
Fred.
  I was able to salvage mine with one or two small files and a lot of patience. The P O or the stealer probably never heard of plastic or aluminum hammers. uglystupid2 Or a steel or iron hammer and a block of wood. tickedoff Guess some folks just don't care iffin they get a might behind and wanna speed things up. Old mechanic told me a long time ago-if ya ain't got time to do it right-when ya gonna find time to do it over. crazy2 RIDE SAFE.
