February 03, 2026, 04:09:47 AM *
Author Topic: Vacuum tube sizes  (Read 2217 times)
gcook1
Grand Rapids, MI
« on: August 16, 2011, 06:14:56 AM »
Finally done installing new jets on my 98 Valk.  I've heard recommendations while I've got Valk guts all over the garage, I might as well replace the vacuum tubes.  The service manual doesn't specify what size hose to use and I don't have one of the old tubes with me.  Does anyone know the size for the vacuum tubes?  And how many feet of hose do you think it takes?  I was going to buy 6 feet since it's relatively cheap but I'd hate to end up being 1 inch short!
Thanks!
« Reply #1 on: August 16, 2011, 07:25:15 AM »
Why not just go ahead and do a de-smog and never have to worry about the vacuum lines again?
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #2 on: August 16, 2011, 07:27:29 AM »
ricky's right.....by doing a de-smog you will eliminate all those pesky vacuum lines, and possible future leaks.
Russell Rice
I think I can, I think I can, I think I can!
Owasso, Oklahoma
« Reply #3 on: August 16, 2011, 07:47:15 AM »
http://www.boostcontroller.com/index.php?item=751&ret=http%3A%2F%2Fwww.boostcontroller.com%2Findex.php%3Fpage%3D1%26category%3D8
gcook1
Grand Rapids, MI
« Reply #4 on: August 16, 2011, 08:16:22 AM »
Showing off my lack of engine knowledge ... desmogging removes all the vacuum tubes, huh?  Mine has already been desmogged so I guess I'm all set!
Jack
Benton, Arkansas
« Reply #5 on: August 16, 2011, 10:35:23 AM »
 I went to AutoZone and bought a pkg of tubing for the windshield washer.  Perfect fit and cheap.  No problems in the past 8 yrs.
X Ring
VRCC #27389, VRCCDS #204
« Reply #6 on: August 16, 2011, 11:53:36 AM »
If you insist on keeping the vacuum lines they're 4mm but 5/32nds will work.
Marty
vic
East TN
« Reply #7 on: August 17, 2011, 08:26:28 AM »
Is 4mm the ID or OD?  I'm thinking of replacing my vacuum tubes with the silicone ones.  Probably will hold up to heat better.
« Reply #8 on: August 17, 2011, 09:26:42 AM »
5/32" is ID....I say that not knowing the conversion  inch to mm so 4mm is ID if they are equivalent
RP#62
Gilbert, AZ
« Reply #9 on: August 17, 2011, 06:51:50 PM »
There's no vacuum tubes on the Valkyrie, its all integrated circuits.  Its old, but not that old.
-RP
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #10 on: August 17, 2011, 07:00:50 PM »
-RP
 Roll Eyes   2funny
ValkFlyer
Antioch, CA
« Reply #11 on: August 18, 2011, 12:47:27 AM »
Quote from: RP#62 link=topic=31917.msg294163# ;Dmsg294163 date=1313632310
-RP
Whoah, that's a relief.......I was wondering were this thing was supposed to go.  Grin
« Last Edit: August 18, 2011, 12:50:21 AM by ValkFlyer » Logged
N0tac0p
« Reply #12 on: August 18, 2011, 08:59:42 AM »
i didn't have as much a hard time with the tubing (gas or vacuum) as i did with what do you use for all those clips that hold them onto the carb bowls,
The Anvil
Derry, NH
« Reply #13 on: August 18, 2011, 09:06:10 AM »
I was gonna say "I prefer the 12AX7 and EL34 combination" but someone kinda beat me to it.
« Reply #14 on: August 18, 2011, 09:14:58 AM »
Those are the drain lines from the bowls and no clips are necessary. The hoses are held on by the tight fit.
