February 03, 2026, 05:50:42 AM *
Author Topic: out of fuel at 100 miles.  (Read 2793 times)
Ghost Rider 2
Downs, Illinois
« on: August 22, 2011, 06:22:58 PM »
  Having intermitent prioblem.  Was on way home from work today.  99.5 miles bike noses over and flipped over to reserve and it took off.  It has done this once before.  I stopped and got fuel at 105 miles.  Bike took 3 gallons. So 35 mpg is about normal.  but I can't figure out why it died at 100 miles at 3 gallons.  It normally goes up into the mid or upper 130 range before going to reserve.
   I am thinking possible fuel strainer.
  Was planning on risding bike on vacation starting Saturday, but now not sure I have time to repair, and I know I don't trust it like it is.
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #1 on: August 22, 2011, 06:26:09 PM »
Have you made any modifications to your fuel line?  I put on the RedEye quick disconnect and ended up taking it off for that reason.
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
Ghost Rider 2
Downs, Illinois
« Reply #2 on: August 22, 2011, 06:36:23 PM »
  No modifications.  Fuel system totaly stock.  Just seems weird it will do it 1 out of 10 or 15 tanks of gas.
« Reply #3 on: August 22, 2011, 06:58:14 PM »
Mine did that. It was the early sign of petcock problems. I had to rebuild the cover set on the petcock. You might also check the vacuum line to the petcock.
BradValk48237
Oak Park, MI
« Reply #4 on: August 22, 2011, 07:19:11 PM »
Ditto on the petcock..... bet the diaphragm has a hole in it........
How do I know?  see my post on here... Fuel Starving...
Brad
Farther
Quimper Peninsula, WA
« Reply #5 on: August 22, 2011, 09:20:35 PM »
It can also be a problem in the vent line, but more likely your vacuum line to the petcock or a failure in the petcock.  Just a guess.
~Farther
rodeo1
« Reply #6 on: August 22, 2011, 09:51:02 PM »
last year i had a tire that wouldn;t hold air, yep you guessed it, bad petcock crazy2
MP
North Dakota
« Reply #7 on: August 23, 2011, 04:57:24 AM »
Typical start of diaphram failure in the petcock.  Put in a new one.
MP
"Ridin' with Cycho"
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #8 on: August 23, 2011, 06:51:33 AM »
Where do you get a petcock rebuild kit? Dealer?
Bullgoose
Bastrop, Tx
« Reply #9 on: August 23, 2011, 07:01:20 AM »
Directline parts has them. Couldn't find the link for it. Called a cover set.
1-888-693-1011
If it's worth doing, it's worth over-doing!
BradValk48237
Oak Park, MI
« Reply #10 on: August 23, 2011, 07:14:11 AM »
Link
http://www.hdlparts.com/fiche_section_detail.asp?section=148614&category=MOTORCYCLES&make=HONDA&year=2000&fveh=3474
   05   COVER SET,rooster
16953-MBZ-B51  (replaces 16953-MV9-000)   001   $37.55   $28.91
Direct Line parts.....I have used for a while and usually have in a couple of days.
Brad
« Reply #11 on: August 23, 2011, 08:28:30 AM »
I think it's too early to worry about it since it has only happened one time before.
Sure would keep an eye on it however.
What was your response when it happened the first time?  That's why I say to wait. It may not happen again.
The only fuel strainer is the screen that is on the petcock that is inside the tank and that is usually never a problem.
An addition of some fuel additive might be a good idea.
And finally, I would suggest to look at the connection between the knob and the petcock to be sure it is operating freely and you can actually feel the detent from the ball inside the petcock seating in the proper position.
Ghost Rider 2
Downs, Illinois
« Reply #12 on: August 23, 2011, 03:53:50 PM »
  I am going to [pull it apart and rebuild petcock and replace strainer.  The reason I was thinking strainer.  My wife has a 750 Shadow. I got where it would only go about 80 miles and run out.  The strainer was collapesed and would not pick up fuel when low in tank.  Whatwever problem is I want it fixed.  I am riding Goldwing on vacation.  Don't have the time this week to ride much and I am bnot going to leave with a bike I am worried about.
kruzn
Illinois
« Reply #13 on: August 23, 2011, 08:22:32 PM »
Jerry,
Ya wimp! Just ride the thing! What's a little fuel delivery issue when you're on vacation? They say "a bad day riding is better than a good day at work", so what's the problem with being out of gas on the side of a back road in Nowhere, Arkansas? Heck, just this past Saturday our trike was out of air in the air shocks (blown seal) and left us "almost" stranded. It's an adventure!
JUST KIDDING YA BUDDY!  Grin Thanks again for dinner last night. You and Cheryl be safe and have a great trip. See ya soon!  Cool
Cruisin' Dave
« Last Edit: August 23, 2011, 08:29:03 PM by kruzn » Logged
Cruisin Dave
VRCC #46
CMA #141825
1997 Honda Valkyrie Tourer SE
2002 Boss Hoss 32 Trike
2015 Indian Roadmaster CSC Trike
1972 Triumph Chopper
1976 Honda CB550F Super Sport
Chiefy
Sarasota, Florida
« Reply #14 on: August 24, 2011, 10:56:36 AM »
Rebuilding after a few years is not a bad idea.  Especially when you see the amount write ups around here about petcock issues.
Chiefy
Sarasota, Florida
« Reply #15 on: August 24, 2011, 10:57:59 AM »
Would have thought it was clogged slow jets!?
olddog1946
Moses Lake, Wa
« Reply #16 on: August 28, 2011, 09:54:30 AM »
Do you really need a repair??????  I had the same thing happen while riding to Spokane for jury duty..100 miles, then reserve....Found that some dumb ass had been running with the choke partway on..turned off the choke, back to 34 mpg.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Chiefy
Sarasota, Florida
« Reply #17 on: August 28, 2011, 10:32:31 AM »
OP said it took 3 gallons to fill up at reserve.  His MPG were good.
