February 03, 2026, 05:50:46 AM *
Author Topic: Need some help.  (Read 1968 times)
Cleaner Man
Grand Rapids, MI (actually Lowell- but who knows where that is)
« on: August 26, 2011, 03:43:34 AM »
My '97 Standard has developed a rear fender problem. It is bending down, and is slightly mis-shaped (sagging).  And now I've noticed a crack on the right side. Does anyone know about a repair, or do I need to replace the tail light section of the fender ($600-$700)?  Are there used fenders available?  Any and all help is appreciated! Cry
« Reply #1 on: August 26, 2011, 03:52:58 AM »
My '97 Standard has developed a rear fender problem. It is bending down, and is slightly mis-shaped (sagging).  And now I've noticed a crack on the right side. Does anyone know about a repair, or do I need to replace the tail light section of the fender ($600-$700)?  Are there used fenders available?  Any and all help is appreciated! :'(
Have you tighten it up ( 2 ) bolts ? Big Mike has several fenders and is a VRCC vendor  www.valkyrieblingandmore.com
« Reply #2 on: August 26, 2011, 04:40:28 AM »
I think the middle bolt that also holds the rear seat may have stripped out.  Drill it out and replace with a bolt and nut if  it has.  Hoser
ricoman
Sarasota, FL
« Reply #3 on: August 26, 2011, 06:16:59 AM »
Hoser is on track. Try this first.
« Reply #4 on: August 26, 2011, 06:30:48 AM »
Once it has started to crack the only repair for that fender piece involves welding and painting.  When mine did that it was the long term result of a slight bump to the rear fender and the resulting stress.
There are used pieces available.  If you're fortunate you'll find one in your color.
Ken Tarver
North Mississippi
« Reply #5 on: August 26, 2011, 09:19:30 AM »
google Pinwal for used parts
Ken
Kylenav
Tampa FL
« Reply #6 on: August 26, 2011, 08:09:52 PM »
+1 on pinwall.  They have several on there E-bay store at all times.  Shouldn't cost more than $200 usually.  They often have an assortment of colors so maybe you will get lucky.
9Ball
« Reply #7 on: August 27, 2011, 07:18:43 AM »
that was a known problem on the '97 model year, early production bikes.  Honda used to replace them under warranty when they were new.  You're a bit outside that now, even if you had bought the extended 4 year warranty.
As others have stated, you'll either need to weld and repaint or find a replacement.
Good luck with it.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
