March 08, 2026, 10:57:31 PM
Need motor
Topic: Need motor (Read 2247 times)
stormrider
Kinsey, AL
Need motor
April 27, 2009, 02:29:26 PM »
for a 98 Kawa zx6r. Other years will work, I think up to a 04-05? I've tried ebay, and several salvage yards. Thought someone might think to ask around and find one at their local shop, or neighbor. My son's budget is very limited so we are checking all resources.
Iron Mike
Re: Need motor
April 27, 2009, 02:58:19 PM »
Can you rebuild it? What happened?
stormrider
Kinsey, AL
Re: Need motor
April 27, 2009, 06:35:51 PM »
rebuilt it and still low compression. It had been used as a drag bike, has titanium valves which can't be shaved. So, either a $1000. head job or a used motor for about the same. Just hoping to find one sitting around in a garage waiting for a new home.
flatsixrider
2000 Standard
Greenville, SC
Re: Need motor
April 27, 2009, 08:03:55 PM »
Quote from: stormrider on April 27, 2009, 02:29:26 PM
try craigslist
Sometimes the appropriate response to reality is to go insane.
JerryB
Takin' it easy!
Michigan
Re: Need motor
April 28, 2009, 05:40:05 AM »
Can you just replace the valves with standard valves?No head job is worth $1K.
Retired and taking it easy!
stormrider
Kinsey, AL
Re: Need motor
April 28, 2009, 05:49:15 AM »
Has 4 mm valves. Regular valves are 5 mm.
X Ring
VRCC #27389, VRCCDS #204
Re: Need motor
Reply #6 on:
April 28, 2009, 06:23:28 AM »
Stormrider, had some time on my hands and found several engines from the mid 90s to '06 and one head. Here are the links.
Marty
98 Engine
http://cgi.ebay.com/ebaymotors/Kawasaki-zx6r-zx-6r-1998-ninja-Engine_W0QQcmdZViewItemQQcategoryZ35592QQihZ005QQitemZ150341805134QQrdZ1QQsspagenameZWDVW
04 Engine
http://cgi.ebay.com/ebaymotors/KAWASAKI-ZX636R-ZX6R-ENGINE-100-WARRANTY-MOTOR-2004_W0QQcmdZViewItemQQcategoryZ34284QQihZ008QQitemZ180350856626QQrdZ1QQsspagenameZWDVW
05-06 Engine
http://cgi.ebay.com/ebaymotors/05-06-KAWASAKI-ZX636-MOTOR-ENGINE-zx6r-6r-zx-636-6rr_W0QQcmdZViewItemQQcategoryZ35595QQihZ026QQitemZ390046856648QQrdZ1QQsspagenameZWDVW
05 Engine
http://cgi.ebay.com/ebaymotors/2005-kawasaki-zx6r-zx6-636-engine-motor-kit-COMPLETE_W0QQcmdZViewItemQQcategoryZ35595QQihZ003QQitemZ130301272138QQrdZ1QQsspagenameZWDVW
95-97 Engine
http://cgi.ebay.com/ebaymotors/95-96-97-Kawasaki-Ninja-ZX6R-ZX6-F-Model-Bare-Engine_W0QQcmdZViewItemQQcategoryZ35595QQihZ017QQitemZ270375404343QQrdZ1QQsspagenameZWDVW
2000 Engine
http://cgi.ebay.com/ebaymotors/00-KAWASAKI-ZX6R-ENGINE-MOTOR-USED-763_W0QQcmdZViewItemQQcategoryZ35595QQihZ025QQitemZ380080729250QQrdZ1QQsspagenameZWDVW
2000 head
http://cgi.ebay.com/ebaymotors/KAWASAKI-ZX6-ZX6R-00-ENGINE-CYLINDER-HEAD-N094_W0QQcmdZViewItemQQcategoryZ10066QQihZ017QQitemZ270299691054QQrdZ1QQsspagenameZWDVW
Iron Mike
Re: Need motor
Reply #7 on:
April 29, 2009, 11:39:05 PM »
Just have the seats cut and lap the valves in. I know you are not supposed to lap the valves but it works fine. Unless the valves are tost. Valve seats, new valve guides and seals, valves should not be that bad? If the crank is good and you have new pistons and the cylineders are good, $1000 on the head is better than $500 gamble on an engine you know nothing about. Just my 2 cents, trying to help.
