November 23, 2025, 02:00:40 PM *
Author Topic: Rear tire rubbing.  (Read 2599 times)
Raverez
No good deed goes unpunished
Central New York State
« on: August 29, 2011, 04:52:43 PM »
not sure why yet, but out riding when I started smelling rubber on left hand turns. Cecked tir eand noticed it was wearing on the right sidewall.  I went darkside last year and this is the first time it has done this. I'm urunning a Yokohama Avid/envigor 205/60- R16. It's was pretty tight on the right side  when I installed it but never rubbed.
Question: will a spacer or several washhers on that side help?
Any other suggeestions?
Thanks.  Raul
« Reply #1 on: August 29, 2011, 05:10:16 PM »
I'm sure others reply will be better. But my first thought was the bearing.
I also don't think you'll be able to add any kind of spacers.
eric in md
« Reply #2 on: August 29, 2011, 05:13:30 PM »
also since you live in ny check the swing arm were its hitting the tar my swingarm rusted . there is a thin piece of metal that wraps around the there . i took wheel off and grinded it off clean then repainted it fix my rubbing .. just check that .
Raverez
« Reply #3 on: August 29, 2011, 05:29:51 PM »
Only seems to be rubbing when leaning into left turns.
This was last year after it was installed
And today
Raverez
« Reply #4 on: August 29, 2011, 05:32:29 PM »
Just started rubbing today. checked air, it was 41psi.
Thunderbolt
Worthington Springs FL.
« Reply #5 on: August 29, 2011, 06:27:07 PM »
or more weight?
Raverez
« Reply #6 on: August 29, 2011, 06:35:33 PM »
Not more than normal. Rode with my son. Done that plenty.
eric in md
« Reply #7 on: August 29, 2011, 06:43:00 PM »
check that rusty swingarm ..
wizard -vrccds#125
Hitchcock Tx.
« Reply #8 on: August 29, 2011, 06:47:03 PM »
Did you do the nut cage mod when you went darks side?  Check the nut on right side rear fender bolt may have come loose. If all is tight. Check left bearing !
wizard -vrccds#125
Hitchcock Tx.
« Reply #9 on: August 29, 2011, 06:50:00 PM »
Looking at the picture closer. It looks like the inside nut on the right rear fender bolt is the bad guy doing the damage uglystupid2
Raverez
« Reply #10 on: August 29, 2011, 07:01:25 PM »
Did the nut cage mod. But will check tomorrow when I remove the wheel
RainMaker
Arlington, TX
« Reply #11 on: August 29, 2011, 11:45:26 PM »
That is definitely the right side rear fender nut.  Daniel Meyer told me to put duct tape on all areas where I thought it could rub and then take a short ride.  Where ever the tape was damaged would be the rub point.   On mine, with the nut cage mod and one washer on the washer mod, it still hit.
Go to 3 washers on the washer mod and reverse the bolt, if you haven't done so, such that the head is inside and the nut outside.  I also ground the head on mine down to half of what it normally was.  Between all of that, I now have good clearance.
The washer mods pushes the fender to the right and away from the tire.
But if it wasn't doing this and now is, then you may have a bad bearing.  I did.
Good luck!
RainMaker
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
« Reply #12 on: August 30, 2011, 12:00:07 PM »
Might be rubbing your nut you used inplace of the nut cage.
sugerbear
wentzville mo
« Reply #13 on: August 30, 2011, 01:12:50 PM »
carriage bolt. been there done that. something worked loose.
Ferris Leets
Catskill Mountains, N.Y.
« Reply #14 on: August 31, 2011, 05:07:54 AM »
I just went through a similar proble.  Very long thread about CT rubbing a few weeks ago.  The culprit was the previous owner.  He put a 3/8" bolt with the head on the inside on the FRONT mounting point.  It is supposed to have a 10mm bolt threaded in from the outside, so there is nothing sticking out on the inside.  Worth looding at.  If you have a nut on the outside of the front mount.  There is your problem.
Raverez
« Reply #15 on: August 31, 2011, 08:11:24 AM »
When I did the nut cage mod I kept the original nut and bolt. But didn't get to it yesterday. Might see if I can work on it tonite.
thanks all for the input.
Raul
« Reply #16 on: August 31, 2011, 09:10:14 AM »
You can crane a little and with a flashlight look up in there under the fender and most likely see where it is rubbing if it is indeed rubbing under there.
The tire rubbing on any metal will have surely polished it quite a bit and that place ought to look like a mirror reflecting in the flashlight beam.
Raverez
« Reply #17 on: August 31, 2011, 04:32:00 PM »
Yep.  nut on the right side is polished up. must be rubbing there. what is the washer mod?
X Ring
VRCC #27389, VRCCDS #204
« Reply #18 on: August 31, 2011, 05:07:57 PM »
Relatively easy.  Keep the rear fender bolt in and remove the middle one.  Slide a washer in between the fender rail and fender.  As the middle of the fender rail is pushed out it pulls the rear of the fender rail and fender out.
Marty
Bone
« Reply #19 on: August 31, 2011, 05:17:02 PM »
Go here there is a couple of links with pictures I found in the archives.
http://www.valkyrieforum.com/forum/tech_archive.cgi
Raverez
« Reply #20 on: August 31, 2011, 05:20:12 PM »
Does this work on an Interstate. Searching the forums, seems everyone that has done the washer mod has a standard.
Grumpy
Tampa, Fl
« Reply #21 on: August 31, 2011, 06:06:00 PM »
Yes, works on the IS, did mine a couple years ago.
Raverez
« Reply #22 on: August 31, 2011, 07:17:08 PM »
you guys made it sound easy.  Almost thought I was going to remove the trunk to get the washer in place. now just need the rear holes to line up so the bolt goes back in.
Thanks , Raul
fordmano
San Jose, CA.
« Reply #23 on: August 31, 2011, 11:44:57 PM »
Might be rubbing your nut.
 uglystupid2 crazy2
And you have a problem with this? Shocked ???
 Cheesy Wink
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
Raverez
« Reply #24 on: September 01, 2011, 05:21:57 PM »
Of course this leads to my finding the bushing on the shock needs replacing. Maybe thats why its seems to be wobbling in turns......
« Reply #25 on: September 02, 2011, 06:38:01 AM »
 uglystupid2 crazy2
 Cheesy Wink
I dont THINK I do, but Kit says I do.  Undecided
