November 23, 2025, 02:00:56 PM *
Author Topic: Handlebar Raisers  (Read 1747 times)
LilAbner
« on: August 31, 2011, 08:17:47 AM »
I want to put handlebar raiser and pull backs on my 97 standard. What size are you guys putting
on your bikes. whos brand are you useing. thanks
« Reply #1 on: August 31, 2011, 09:00:40 AM »
Probably the biggest consideration is if you want to do all the work necessary such as changing the cables, hydraulic lines and electrical wiring.
If you prefer to try and stay with everything you already have, you will be severely limited in what you can actually do.
Mostly those that do the limited change are restricted to aftermarket risers in the four to five inch range which would still involve rerouting the throttle cables.
The Anvil
Derry, NH
« Reply #2 on: August 31, 2011, 09:07:24 AM »
The risers I just tool off Eddie's new (to him) Valk were 6 inches, maybe longer. The PO did nothing more than reroute the throttle cables behind the triple tree instead of in front of it.
They were nice chrome risers too and he may be looking to get rid of them. If you're interested I'll ask him to bring em along tomorrow night and I'll put up some pics and specs.
« Reply #3 on: August 31, 2011, 09:10:46 AM »
I put Aeromach risers on my bike, they're quite a bit different than what came on there, but I think
the ones that were on there were cut down... no need for different cables or brake lines...
It would pay to be picky about how stout the ones you get are... Daniel Meyer's bars almost
came off in his hands because of some cracked risers...
F6AJ
Mobile,Alabama
« Reply #4 on: August 31, 2011, 09:20:47 AM »
I was looking at BigBF's 6" rise  with a 2" pull back, he advertised them on the Classifieds .
He assured me that I can use stock cables and lines,just re-route them. Anybody got experience with them?
AJ
The Purple Haze
Proud Member # 23359 Purple '97 Std CSC Trike
Glendale, Arizona
« Reply #5 on: August 31, 2011, 09:49:19 AM »
I have BigBF's risers and they are great.  Yes, all you have to do is re-route the cables and reverse a couple of the handlebar cable holders.  I bought them right after one of my Zoom 5" risers BROKE IN HALF as I was riding....DO NOT BUY ZOOM RISERS!!!
Tropic traveler
Silver Springs, Florida
« Reply #6 on: August 31, 2011, 05:49:38 PM »
I have the Aeromach/Lamonster risers like Hubcap's on my '97 & I love them. They were already on the bike when I bought it. They do use stock length cables, I broke a throttle cable a few months back & the replacement stock cables fit perfect.
When I started to fix up the new to me '99 I wanted to get the same feel as the '97 w/out spending too much $$. I bought these riser extensions through E-Bay for $49 & they seem to have the same  or very close pull back & rise as the Aeromach/Lamonsters do. cooldude
'13 F6B red for Kim
Farther
Quimper Peninsula, WA
« Reply #7 on: August 31, 2011, 08:40:50 PM »
That's what I have except yours appear to be more shiney.  Works well for me.
~Farther
BIG--T
The Twilight Zone
« Reply #8 on: September 01, 2011, 06:26:20 AM »
I'm glad someone asked that question. I have some 5 1/4" risers and wanted to be sure they would work without changing cables. I know I'll have to reroute. Wink
« Reply #9 on: September 01, 2011, 08:29:18 AM »
Here's a riser comparison.....
http://www.timskelton.com/valkyrie/how_to/risers.htm
The risers BigBF sells are the Harley Davidson style risers from a HD Deuce.  He cuts off the bottom so they'll fit the Valk.  That's a nice service since not everyone has access to the tools to do that.  Buy his and install.....couldn't be easier.
« Last Edit: September 01, 2011, 08:32:52 AM by BF » Logged
Willie
I am better than I deserve to be
Lake Jackson, TX
« Reply #10 on: September 01, 2011, 10:50:20 AM »
Does Big BF still sell them, if so, where do you go to order them??
Willie
2002 Black Standard
1974 Suzuki 100TC
VRCC #32624
« Reply #11 on: September 01, 2011, 11:41:23 AM »
He has an ad in the classifieds for the risers.  And he has a web site.......
http://www.bigbf.com/
Willie
Lake Jackson, TX
« Reply #12 on: September 01, 2011, 12:04:08 PM »
yeah - I went to the website before i posted and did not see risers on his product list.
Willie
2002 Black Standard
1974 Suzuki 100TC
VRCC #32624
The Anvil
Derry, NH
« Reply #13 on: September 01, 2011, 12:16:31 PM »
Just you know, you can remove the kill switch from the upper half of the switchgear housing (two small screws) loosen the headlight bracket and slide the throttle assembly while still attached to the starter/cable portion between the fork tube and headlight so you don't have to disconnect the cables from the throttle tube which may be tough to do if the cables are tight as they were with my buddy Eddie's bike.
WDAN
Irving, TX
« Reply #14 on: September 01, 2011, 07:30:07 PM »
I also installed BigBF's risers. Could not be more pleased.
WDAN
Irving, TX
