February 03, 2026, 09:10:03 AM *
Author Topic: aftermarket speakers for 2000 I/S  (Read 3309 times)
Desert Dog
Reno NV/Apache Junction AZ
« on: September 05, 2011, 03:55:01 PM »
Just bought a 2000 I/S and love everything about it but the speakers. Does anyone make a bettersounding speaker that''s compatible with the I/S? Cool
1997 Tourer, green and cream, 2000 I/S, blue &silver,  2000 I/S Trike, Blue & Silver, 04 Goldwing trike, titanium, all compliments of my Darling wife of 21 years. Third time really is the charm!
tank_post142
south florida
« Reply #1 on: September 05, 2011, 04:22:29 PM »
http://s161.photobucket.com/albums/t220/wixthedog/Rear%20Speaker%20Upgrade/
if i remember right they are polk audio db501 speakers
I got a rock Sad
VRCCDS0246
PhredValk
Edmonton, Alberta, Canada
« Reply #2 on: September 05, 2011, 10:50:09 PM »
Are these Polk speakers 4"? And do they also replace the front speakers?
Fred.
VRCCDS0237
fordmano
San Jose, CA.
« Reply #3 on: September 06, 2011, 01:43:54 AM »
Fred, the answer is YES to both questions.
The db401 and the db501 have EXACTLY the same dimensions but the db501 is rated to have a 10hz lower frequency response range. This spec should give you a slightly better sound and be capable of giving a small amount better BASS response.
I did not know this data until I had already ordered mine so I have db501's in the fairing and db401's in the trunk mounted arm rests. Still looking at adding a slim line 8" powered subwoofer in a flat cabinet under the trunk where the CB would mount.
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
valkyriemc
NE Florida
« Reply #4 on: September 06, 2011, 02:03:38 AM »
I don't really like the I/S speakers either. But as I recall the speakers have an odd impedance like 3 ohms, do the polk speakers match the original design spec's? Improved frequency response is good but solid state amplifiers usually have a minimum impedance that they can tolerate. And if the impedance is greater than the design calls for then there's a mismatch that can reduce efficiency.
« Last Edit: September 06, 2011, 02:05:34 AM by valkyriemc » Logged
Veteran USN '70-'76
Cattman
Franklin, IN
« Reply #5 on: September 06, 2011, 05:17:12 AM »
I put in the DB501's in both front and rear this past spring. Major difference in sound going down the road. Before needed vol. set to 27-30, now 18-21. Great sound. Do search on this site for installation modification instructions. Easy to do. cooldude
frosty
« Reply #6 on: September 06, 2011, 07:11:25 AM »
Are these speakers Waterproof?  Weres the best place to buy?
tank_post142
south florida
« Reply #7 on: September 06, 2011, 07:14:09 AM »
yes waterproof check ebay and amazom for best prices.
I got a rock Sad
VRCCDS0246
Momz
ABATE, AMA, & MRF rep.
« Reply #8 on: September 06, 2011, 01:27:05 PM »
Try www.autotoys.com for some small amplifiers that can be hidden either under the trunk or within the fairing itself.
They have both 2 and 4 channel models cheap.
« Last Edit: September 06, 2011, 01:30:44 PM by Momz » Logged
ALWAYS QUESTION AUTHORITY!
valkyriemc
NE Florida
« Reply #9 on: September 06, 2011, 03:48:36 PM »
DB 501 specifcations
Overall Frequency Response 85Hz-22kHz
Nominal Impedance 4 ohms
Power Handling (continuous) 45 w
Power Handling (peak) 135 w
Efficiency 92 dB
Veteran USN '70-'76
« Reply #10 on: September 06, 2011, 05:35:10 PM »
Links for Polk install.
REAR SPEAKERS
FRONT SPEAKERS
http://s161.photobucket.com/albums/t220/wixthedog/Front%20Speaker%20Upgrade/
NITRO
Eau Claire, WI
« Reply #11 on: September 06, 2011, 06:25:01 PM »
Electrical connections also has a wiring harness for the rear speakers for around $15. It's pretty darn handy for the install.
When in doubt, ride.
Mr.BubblesVRCCDS0008
« Reply #12 on: September 07, 2011, 06:24:18 AM »
Goldwing 1500 replacement speakers from J&M   are direct bolt ins 4.5in front 4in for rear and reasonable priced. Got mine from HDL. Sale on now thru the 8th of sept.
Cattman
Franklin, IN
« Reply #13 on: September 07, 2011, 09:44:08 AM »
I picked mine up on ebay for under $50 per pair shipped. Polk has an ebay store and periodically have great deals. cooldude
Desert Dog
« Reply #14 on: September 07, 2011, 10:18:51 AM »
 coolsmiley Ok, I ordered the polk 501s. Bought them on Amazon for less than half of what they were on Polks website. Thanks for all the input, especially the installation instructions. I'll let you know how it goes.
