February 03, 2026, 09:09:42 AM *
Author Topic: How to remove I/S fuel sender from tank?  (Read 1674 times)
BonS
Blue Springs, MO
« on: September 07, 2011, 07:10:46 PM »
I have the tank off and empty and have removed the four nylock nuts that hold the sender to the tank. I've gently been rotating it around-and-around to find the magical orientation required to get the sender out of the hole that it has to fit through - without luck. I can see that the float/resistor portion is detachable from the brass stem but I haven't even attempted to disassemble the unit while it hangs half out the of tank without being sure that this is the right thing to do. The problem is: the white nylon plastic that is the actual sender circuit doesn't fit through the exit hole!? Does anyone know the magic words? (I thought it was XYZZY.)
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: September 07, 2011, 07:17:19 PM »
It could be as simple as valkyrienorway.com where you can download the scanned version of the shop manual.
Marty
Russell Rice
I think I can, I think I can, I think I can!
Owasso, Oklahoma
« Reply #2 on: September 07, 2011, 07:24:49 PM »
IF you think it is fun getting it out, wait until you put it back in uglystupid2 I just took my time and " wiggled" it gently with a little light pressure pulling it out. Good luck cooldude
BonS
Blue Springs, MO
« Reply #3 on: September 07, 2011, 07:40:15 PM »
I visited Dag's site and checked his manual and I also have a Chilton's manual. Neither addresses the float assembly. I think I'll take another shot at wiggling - again. I hate forcing delicate things - tends to not end well.
BonS
Blue Springs, MO
« Reply #4 on: September 07, 2011, 08:49:44 PM »
Okay, got it. It's a 3-D maze that has about 6 turns to thread the white nylon part through the hole . Going back in was more difficult but  tickedoff I got it done. Thanks all!
« Reply #5 on: September 08, 2011, 08:40:49 AM »
Caution!  If the wires aren't exiting to the rear then you have it in backwards and it won't give you an accurate reading.
BonS
Blue Springs, MO
« Reply #6 on: September 08, 2011, 11:16:36 AM »
Thanks John, good point as it will bolt up in more than one orientation. I marked mine before I removed it to be sure I got it back in right.
« Reply #7 on: September 08, 2011, 12:28:07 PM »
cooldude cooldude Good thinking.
Russell Rice
Owasso, Oklahoma
« Reply #8 on: September 08, 2011, 07:34:01 PM »
A little " Wiggle " goes a long way Cheesy
MP
North Dakota
« Reply #9 on: September 09, 2011, 05:00:47 AM »
+1
Kind of backwards.  The hookup is to the front, ie to the dash.  So, you think the wires coming out of the sender should go ahead, but they go to the rear. It will go in the tank that way, but the reading is wrong.
MP
"Ridin' with Cycho"
« Reply #10 on: September 09, 2011, 06:10:33 PM »
My IS tank wires went out the side, and I was reading 1/3 when empty.
I was told at that time that the wires should be attached at the rear of the tank (clipped).
