November 23, 2025, 02:26:13 PM *
Author Topic: sharp snap when starting  (Read 1458 times)
slider
mulberry arkansas
« on: September 12, 2011, 11:36:21 AM »
when starting the valk at time there will be a sharp snapping sound,like a rubber band snapping on paper.Everything works fine it just  makes this sound at times-97 stock valk standard.I have cked electrical connections and all appear to be clean and tight.Anyone have any I deas??Help please
a proud navy veteran
« Reply #1 on: September 12, 2011, 12:00:51 PM »
So are you saying it sounds like an electrical spark or something like that?
Or do you think it is a mechanical sounding like two pieces of metal hitting?
slider
mulberry arkansas
« Reply #2 on: September 12, 2011, 03:38:20 PM »
sounds electrical  ,have done some investigating and  seems louder on right side of bike..dosent do it everytime about every 3rd-4th time its started.
« Reply #3 on: September 12, 2011, 05:29:45 PM »
Do a search and you'll find discussions on this issue about 3 months ago.
I think it's the starter relay. Just an electrical Snap, sometimes when the bike is hot/warm. Others had different thoughts.
Kingbee
VRCC# 576
Northern Illinois
« Reply #4 on: September 12, 2011, 06:45:53 PM »
Slider, if that happens in hot weather, when the engine is heat soaked, when the bike is re-started after a short period of time, it's perfectly normal.   It's kind of a pre-ignition caused by hot deposits in the combustion chamber.
1999 Interstate
2000 Interstate
2004 Rune
FryeVRCCDS0067
Brazil, IN
« Reply #5 on: September 12, 2011, 06:46:24 PM »
My 97 has done it occasionally since I bought it in 2004. Only happens if the motor is hot. Almost sounds like striking an arc with a stick welder but only lasts a split second.
I long ago decided it's nothing to worry about. But, after reading the above posts and thinking about it, I don't think it's happened since I replaced my starter relay.
lucky_1_chris
Arlington, TX
« Reply #6 on: September 12, 2011, 08:57:14 PM »
Mine does the same thing when hot, and has only been off for a short time. Usually after filling up. My VTX did the same thing.
1999 Valkyrie Interstate
slider
mulberry arkansas
« Reply #7 on: September 12, 2011, 10:19:39 PM »
thanks to you all,now I feel much better about my girl...!
PhredValk
Edmonton, Alberta, Canada
« Reply #8 on: September 13, 2011, 08:42:14 AM »
The discussion 3 months ago was mine. Due to hitting the wrong ramp I ended up smack dab in the middle of downtown Toronto, Younge and Bloor, in the middle of rush hour, with my reserve warning blinking.
Knowing it can take an hour or so to go a mile, and no gas stations for a few miles, I decided to turn her off at red lights to extend my reserve gas. 90ยบ and my fans were running, so close to overheating. The snap surprised me and got me worried, so I asked about it here.
Consensus was that it wouldn't damage anything, and that was 4,000 miles ago.
Fred.
VRCCDS0237
