November 23, 2025, 02:41:33 PM *
Author Topic: Want a pingle...have questions.  (Read 2668 times)
Danny
Tucson, Az
« on: September 13, 2011, 04:07:06 PM »
Does pingle come with everything i need for install or are there other things like gaskets etc... i need to purchase.
MP
North Dakota
« Reply #1 on: September 13, 2011, 04:11:29 PM »
Everything included.  No gaskets used.  Just screw out the OEM,and screw on the Pingle.  Then, put a cap on where the vac line comes out of #6.  Ready to go!
MP
"Ridin' with Cycho"
dubsider
Flat6 baby #33034
Dublin GA
« Reply #2 on: September 13, 2011, 04:48:48 PM »
MP.. is the reserve the same?  and what about the filter screen.. let us know.
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: September 13, 2011, 05:13:53 PM »
The reserve is about half that of the stock petcock.  You can extend the pickup tube but you lose the screen.  You'd have to install an inline fuel filter then.
Marty
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #4 on: September 13, 2011, 05:38:23 PM »
marty....don't forget....you need to put a clamp on the gas hose where it connects at the pingle valve......the pingle outlet barb size is smaller than the stock petcock.
« Reply #5 on: September 14, 2011, 05:26:53 AM »
True, but thats the best part of the whole install......makes removal easy and re-connect even easier when removing the tank
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #6 on: September 14, 2011, 08:33:59 AM »
That depends.
On a manual petcock you may want to put a Dan Marc Electric Shut Off in series before the "fuel T."
Save a horse, ride a Valkyrie
X Ring
« Reply #7 on: September 14, 2011, 08:10:58 PM »
MP asked about the reserve and the screen.  I answered those questions.  No more, no less.
Marty
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #8 on: September 15, 2011, 01:52:51 AM »
We used to use an old trick - find a piece of flexible line, about the same size as the "gas hose", about 1/4" to 1/2" long. With a little oil and elbow grease, you can slide it over the gas hose, the last 1/2". It squeezes down the gas line, for a tight fit on the nipple, but allows you to remove it fairly easy with a stiff pull, without needing any tools.
R
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
