November 23, 2025, 02:54:31 PM *
Author Topic: corner sway/wobble  (Read 1816 times)
bigfish_Oh
Allis
West Liberty,Ohio 43357
« on: September 14, 2011, 07:21:01 AM »
   I did just notice while riding single I get a little sway/wobble in a curve, 60mph or over. I assume it has to be tire pressure(CT) or shock setting because I am 180 #'s light ? I feel perfect when 2 up.
any ideas?   thanks
2012 HD Road King Classic, Teq sunrise/HD Orange
2009 HD Nightster,orange
1974 CB550F,org
1999 Valkyrie,orange/Black (20K)
2009 GMC 3500 Duramax CC Dually 4wd (new)
1957 WD45 Allis Chalmers Grandpa bought new
1982 CBX (new)
1980 CBX (6K)
1979 CB750F (new)
1958 Lambretta TV175 (Dad's new)
4
sugerbear
wentzville mo
« Reply #1 on: September 14, 2011, 07:23:36 AM »
shock bushings ok?
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #2 on: September 14, 2011, 07:26:40 AM »
Check your upper shock bushings...  Bolt should be 'dead center' in the upper shock eye.  If not, they are worn, and should be replaced.
There are a couple of VRCC members that offer replacement 'lifetime' bushings.
Gary, through Chet's Rattlebars store, but looks like he has retired;
http://www.rattlebars.com/
Or Daryl, at Xf6 Customs;
http://www.xf6-custom.com/partpages/bushings.html
Both great guys!
Black Dog
Don't you know...
Farther
Quimper Peninsula, WA
« Reply #3 on: September 14, 2011, 07:58:25 AM »
It has been reported that Hondaline VTX poly bushings work too.
~Farther
valkyriemc
NE Florida
« Reply #4 on: September 14, 2011, 08:05:46 AM »
I have those and I like 'em so far, VTX that is.
Veteran USN '70-'76
bigfish_Oh
Allis
« Reply #5 on: September 14, 2011, 08:27:11 AM »
but the bushings would work fine with 2 people riding?
are shock bushings wore out even when they are hard to take on and off?, I've had shocks off many times, building trailer hitch hitch and solving rubbing.
  I can make bushings, the shocks are the short list of upgrades
thanks
1974 CB550F,org
1982 CBX (new)
1980 CBX (6K)
1979 CB750F (new)
4
tank_post142
south florida
« Reply #6 on: September 14, 2011, 09:15:48 AM »
weight directly over the shock will keep them from moving around on the stud as much.
I got a rock Sad
VRCCDS0246
« Reply #7 on: September 14, 2011, 09:37:50 AM »
Check to see if the rubber bushings look oblong around the bolt.
« Reply #8 on: September 14, 2011, 10:17:13 AM »
any ideas?   thanks
I don't understand every response "going off" about the rear shock bushing but I think you are correct about it being possibly connected to air pressure in the rear tire, also I would say tire pressure in the front tire is even more of an influence.
A lot of that (sway/wobble) can also be rider induced due to road condition and "the rut" which is ever present on the road.
You have to keep in mind that a bump on a road curve will cause the bike to feel like it's wobbling/swaying and this is only due to the fact that the bike is leaning over and the forces from the road are vertical while the bike is not!
« Reply #9 on: September 14, 2011, 10:54:09 AM »
any ideas?   thanks
My CT did this 2 up in curves, esp on bridges. It would 'bounce/ twist. Would not do it 1 up. I up the PSI and its perfect.
sugerbear
wentzville mo
« Reply #10 on: September 14, 2011, 12:48:26 PM »
any ideas?   thanks
sorry but i didn't "go off" just asked a simple question.  ???
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #11 on: September 15, 2011, 02:57:52 AM »
any ideas?   thanks
If I recall, you are running a CT, correct? I'm running the General Tire Altimax, at between 38 and 44 psi - still playing with it a bit. I have one pretty nice sweeper, that I go on about twice a week, and notice that I feel a similar "sway/wobble". I have new shock bushing, the harder ones here on the forums (Gary comes to mind). Still have that feeling, though. I have decided that it has more to do with the fact that I have to actually hold the tire in the turn, so I feel it more in the handlebars, than a MT. Don't know how yours feels, mine is very slight, just enough so I know it's there. I do know that I have to have a heavier hand, with the CT, and I think the same amount of wobble, wouldn't be noticeable, or AS noticeable with a MT.
I could be wrong, but it's not enough to sway (pun intended) me to go back to a MT, to find out.
BTW, you mentioned in a thread that you made your own trailer hitch - do you have pictures posted anywhere?
R
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
