February 03, 2026, 10:42:02 AM *
Author Topic: Rear axel sleeve  (Read 1899 times)
ndkid
« on: September 28, 2011, 10:05:17 AM »
Can any one tell me which way the rear axel sleeve goes, it has a bell shaped end and I took it apart some time ago and not sure which way it needs to go back ...
Thanks for any help!
« Reply #1 on: September 28, 2011, 10:17:45 AM »
It can only go one way...........you cannot put it together backwards.  If its the one that goes inside the final drive it needs to go all the way in and butt up against a steel sleeve at the outside edge of the hole
ndkid
« Reply #2 on: September 28, 2011, 10:34:02 AM »
I looked at the parts diagram and it shows the bell shaped end going towards the finial drive, if I put the narrow end towards the final drive it feels like it slides in, sort of! Any way I put it togeather with the narrow end against the final drive and now I'm thinking is this right!
« Reply #3 on: September 28, 2011, 10:56:35 AM »
If you have the wheel on and that spacer is in then its right, you cannot put it together backwards......same with the u-joint.......
Valkpilot
What does the data say?
Corinth, Texas
« Reply #4 on: September 28, 2011, 11:46:20 AM »
The parts diagram is wrong.  The bell shaped end should be toward the wheel; the narrow end toward the pumpkin.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
ndkid
« Reply #5 on: September 28, 2011, 01:03:09 PM »
Thanks! I feel better now, that's how I put it in. Didn't want to screw up things and I've been knowen to do that!
« Reply #6 on: September 28, 2011, 04:15:15 PM »
If you guys are talking about item 4, it's shown correctly; If item 3, it should go in from the right side of the bike not as shown on the left side.
« Reply #7 on: September 28, 2011, 05:47:46 PM »
What he is talking about is not pictured in that fishe
Its #20 on this one
http://www.hdlparts.com/fiche_section_detail.asp?section=148039&category=MOTORCYCLES&make=HONDA&year=1997&fveh=3465
« Last Edit: September 28, 2011, 05:50:20 PM by Chrisj CMA » Logged
Valkpilot
Corinth, Texas
« Reply #8 on: September 28, 2011, 05:54:56 PM »
That's what I thought too.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #9 on: September 28, 2011, 06:38:52 PM »
one end of the sleve has a little polished place on it at the end, and the other end has a little bit of a flair to it.     the polished end (small end) goes into the final drive, and the flaired end goes to the outside.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #10 on: September 28, 2011, 06:42:03 PM »
i think you are talking about # 20...the little end goes into the final drive and the big end faces out.
« Reply #11 on: September 28, 2011, 06:43:27 PM »
Agree 100 % with Jeff on this....You CANNOT put it in wrong it will only go in one way.
ndkid
« Reply #12 on: September 29, 2011, 09:01:38 AM »
Thanks guys! Yes, I was refering to # 20
