January 28, 2026, 01:55:06 PM *
Author Topic: R/R rear shock  (Read 2659 times)
DaveC
'00 Standard Valk,VRCC#30226
« on: April 30, 2009, 12:44:14 PM »
I want to remove & replace the rear shocks on a '00 Standard. I realize it would be easier to do with a motorcycle lift, but has anyone done this using a floor jack?
If so, where is the jack placed to raise the motorcycle? I have a helper to steady the motorcycle while on the jack. Raising 2-3" should be enough?
the hobo
« Reply #1 on: April 30, 2009, 12:52:10 PM »
the hobo
When I take my shocks off I raise the bike until the weight on the shocks is "neutral"... the
tire is still on the ground but the shock is neither under compression nor tension.
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #2 on: April 30, 2009, 04:07:59 PM »
I did mine one at a time... and had a helper lift on the back of the bie to realign it.
It took a while and got me frustrated.
Jabba
DaveC
« Reply #3 on: May 01, 2009, 08:48:22 AM »
Thanks guys, cooldude
got it done..............just took a little jigglin' & fiddlin'
the hobo
