November 23, 2025, 03:05:20 PM *
Author Topic: About vacuum lines...  (Read 2842 times)
Art708
Jacksonville, FL
« on: September 29, 2011, 01:18:38 PM »
  So what is controlled by vacuum on the Valk......the petcock and the pair valves?
 So if one has a manual petcock what would happen if one just capped off all the vacuum lines and just left the pair valves and crap where they are? Do the pair valves do anything without vacuum applied or just sit there taking up space?
Art
 2014 Kawasaki Concours 14
  Black
Chiefy
Sarasota, Florida
« Reply #1 on: September 29, 2011, 03:18:05 PM »
If you install a manual petcock, you have to cap off the port on Carb 6 where the vacuum line starts.  Easy-Peasy.
If you want to undo the Pair valves, you need to do a "De-smog" procedure on it.  Easy if you're a good wrench.  Not bad if you're an average wrench, and doable, (albeit nerve wracking) if you're a rookie.
« Reply #2 on: September 29, 2011, 04:49:55 PM »
You can pull all the hose that connects to the pair valve with no ill affects if you cap the vacuum ports that are on the back side of the intake risers.
Art708
Jacksonville, FL
« Reply #3 on: September 29, 2011, 05:53:32 PM »
   That's what I was thinking. So you could do a de-smog by just capping all of the vacuum ports and not have to take the bike apart and remove stuff and plug holes, etc.
Art
  Black
« Reply #4 on: September 30, 2011, 09:23:50 AM »
Sure!
There will then be a lot, and I mean a lot of crap there on top of the motor that is taking up room, affecting the air flow, and generally cluttering up that area.
But you certainly don't have to remove it at all.
Art708
Jacksonville, FL
« Reply #5 on: September 30, 2011, 09:48:35 AM »
  Maybe one day I'll work up enough courage to dig into the de-smog job. Thanks for the replies.
Art
  Black
Farther
Quimper Peninsula, WA
« Reply #6 on: September 30, 2011, 09:51:41 AM »
If you ever think your local/state government will mandate emissions test then leave the smog equipment on.  I am confident that the Valk would pass the tail pipe test but if there is a visual equipment check, the Valk could fail.
~Farther
« Reply #7 on: September 30, 2011, 10:09:39 AM »
When cows learn to fly!
The Valkyrie would be so old as to be grandfathered in for sure!
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #8 on: September 30, 2011, 10:47:39 AM »
Careful what you ask for, technology improves every day.
I guess we can all get in line now for a smog check.
« Last Edit: September 30, 2011, 10:57:05 AM by Fudd » Logged
Save a horse, ride a Valkyrie
Farther
« Reply #9 on: September 30, 2011, 01:50:10 PM »
You have some insight into the workings of various state legislatures that others do not?
~Farther
Art708
Jacksonville, FL
« Reply #10 on: September 30, 2011, 02:32:33 PM »
     Or not.
Art
  Black
