November 23, 2025, 03:23:29 PM
bad back fire
Topic: bad back fire (Read 1525 times)
beamerwelder
bad back fire
September 30, 2011, 04:26:34 PM »
i have a bad back-fire from 1200 to 3500 rpms. #6 cyclinder is the culprit- it has compression, been desmoged, carbs cleaned, plug firing. any suggestions.
John U.
Southern Delaware
Re: bad back fire
September 30, 2011, 05:18:20 PM »
The plug may fire at idle when you check it but under load it can still miss.
How did you determine that #6 is the problem? If you are sure it's #6 try changing that plug and see; since they're not expensive you may be wise to replace them all.
YoungPUP
Valparaiso, In
Re: bad back fire
September 30, 2011, 06:24:24 PM »
Check the vacuum line for the petcock, it should be connected to the #6 intake, the hoses like to split at the ends and leak. May try moving the coil pack for that cylinder set and see if the backfire moves with it.
99 STD (Under construction)
electdroid
Re: bad back fire
October 02, 2011, 04:53:26 PM »
My Valk started to backfire on overrun (closed throttle from higher revs). It was from water in the gas--I cured it with about 1/2 cup of methyl hydrate (gas line anti-freeze) in the tank.
Farther
Quimper Peninsula, WA
Re: bad back fire
October 02, 2011, 07:21:05 PM »
It has been a long time since I've heard methyl hydrate used for methyl alcohol.
~Farther
beamerwelder
Re: bad back fire
October 04, 2011, 03:40:32 PM »
the problem was a weak coil. fired at low speed on the bad side but at 2500 rpms it quit firing. thanks for the help.
=> InZane XXV
