February 03, 2026, 10:41:47 AM *
Author Topic: Adjusting choke cable?  (Read 2122 times)
artyc264
Randolph, Massachusetts
« on: October 05, 2011, 01:45:29 PM »
I felt like I was going to snap my choke lever on my 03 Standard. It took a lot of force. I read on here to lube everything. I removed the two chrome covers and lubed the linkage, then lubed the handlebar area. Now my lever is very easy to push down. Now the problem is it springs right back up. I tried adjusting the cable. It didn't matter where I set it. It just sprang back. Any tech tips? Thanks, Arty
« Reply #1 on: October 05, 2011, 01:52:10 PM »
1st word of advice, the hard push was normal.
So let it wear itself back to normal.
Just LEAVE it and other things alone.
Ride the Phat lady and quit messing with stuff.
As Forrest Gump (<<Modified here) would say, That is all I have to say on that subject.
Gomer Pyle was my Marine Corps Buddy.
« Last Edit: October 05, 2011, 10:17:41 PM by R J » Logged
rangernight
New Orleans, LA
« Reply #2 on: October 05, 2011, 02:00:59 PM »
Don't think Gomer Pyle was the wise one------Forest Gump maybe Shocked
« Reply #3 on: October 05, 2011, 10:16:23 PM »
Ya'll is correct, I'll modify the message,    Tanx.
9Ball
« Reply #4 on: October 06, 2011, 06:00:35 AM »
just think of it as an automatic choke release....mine does the same thing.
Since you shouldn't need to have the enricheners on for very long after startup, just hold a thumb on the lever for the 20 seconds, then release.
Better this than snapping cables or levers....I lubed mine over 3 years ago and it still does this.  Hasn't been a problem for me.
« Last Edit: October 06, 2011, 06:36:40 AM by jrhorton » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Rocketman
Seabrook, Texas
« Reply #5 on: October 06, 2011, 06:21:48 AM »
Other than jrhorton, we're not being terribly helpful on this.  Hindsight doesn't help fix the problem.
If jrhorton's suggestion doesn't work for you, then I would suggest trying to clean up some of that lube if you can, to get it back to it's rougher state.  Clean anything you can get to.  If you sent lube down the cable sheathing, try sending some compressed air down there to try to blow some of it out.
I haven't ever had this issue, so I'm just speculating at this point, but they are at least some ideas to try.
« Reply #6 on: October 06, 2011, 07:25:02 PM »
It is possible to adjust a new cable so there is no hard spot to push, but it is a PIA.  Got mine just right after a  hour cussin and sweating. The secret is adjusting the tightness on the choke slider screws.  Smooth all the way down, quarter inch up to warm up, full open in 15 seconds to a minute, depending on the temp.  Hoser   Grin
Chiefy
Sarasota, Florida
« Reply #7 on: October 07, 2011, 12:14:29 PM »
Choke?  We don't need no steenking choke in Florida!
« Reply #8 on: October 07, 2011, 12:28:42 PM »
I don't think you will be able to make the system work any easier Hoser because you are actually pulling on six separate springs (one for each valve) and that is the resistance you feel when you're trying to activate the choke.
« Reply #9 on: October 07, 2011, 04:22:25 PM »
I wasn't speaking of doing it in the future, Rickey, I did it 6 months ago when I put on a pair of new cables, and it works as I described,  I doubt it can be adjusted with old sticky cables, but new ones which are very free in the housing they come with, can be adjusted so there is no hard zone at the end of applying the choke. The springs are just tiny little things that don't a much tension at all, just enough to hold the choke closed. I am convinced that most of the resistance is in the cables as they wear.  Like I said it is a pita, but worth the time and trouble.  I replaced the cables because the top one broke from being stretched many times over the ten years I have owned my bike.  Cool Hoser
« Last Edit: October 07, 2011, 04:29:50 PM by Hoser » Logged
Earl in Pensacola
« Reply #10 on: October 08, 2011, 04:05:50 PM »
MY choke cable is the original with 243K and it WERE very "tight" the last half of the stroke when NEW.   I lube the lever etc. (several years ago), then the other end (where the carb's are) and all sliding parts.  There is now only a slight resistance from the half way mark to full choke.  So, it would seem to me, that it simply wasn't properly lubed at the factory.
« Reply #11 on: October 08, 2011, 05:09:38 PM »
Probly wasn't lubed properly at the factory, but the new ones are!   cooldude hoser
