February 03, 2026, 10:41:41 AM
Power port/Ciggie lighter
Topic: Power port/Ciggie lighter (Read 1735 times)
Chiefy
Sarasota, Florida
October 09, 2011, 01:48:59 PM »
Do you guys generally connect them switched with the ignition, or straight to the battery? I can see pros and cons to both. Just don't know if there is some type of defacto standard.
I can do the wiring either way, I have a relay and understand it fully.
Farther
Quimper Peninsula, WA
Re: Power port/Ciggie lighter
October 09, 2011, 01:55:08 PM »
I have a cheap one wired directly to the battery through an inline fuse. That is about the extent of my electrical skills.
~Farther
Chiefy
Sarasota, Florida
October 09, 2011, 02:20:12 PM »
Quote from: Farther on October 09, 2011, 01:55:08 PM
I guess my overly paranoid persona foresees some crazed vandal fooling with my 12v while I'm having lunch.
Was thinking straight to the battery with a fuse should be fine.
X Ring
VRCC #27389, VRCCDS #204
October 09, 2011, 02:44:30 PM »
Mine runs through my aux fuse panel which is relay controlled from the accessory circuit.
Marty
PhredValk
Edmonton, Alberta, Canada
October 09, 2011, 04:51:15 PM »
My power points and USB ports are on a fusebox with relay from the Aux leads, so only on with the key. My cig lighter is direct to the battery so I have one power point to use with my compressor etc. If you're sure you will dissconnect whatever is plugged in, no relay needed, but I've left my GPS and Ipod connected several times, so am glad the power is keyed.
Fred.
VRCCDS0237
PAVALKER
Pittsburgh, Pa
October 09, 2011, 05:03:20 PM »
Power Port(s) wired directly to the battery and fused. I use them to charge my cell phones or use the GPS.... and I don't want to have the key on or bike running all the time I use either the phone charger or GPS. I have one power port up front for the GPS and one near the rear pass seat so "she" can plug her or my phone if if need be. I also use it the charge my camera or cell phone when I am stopped eating or otherwise.... and in that case it also needs to be direct wired.
John
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
Reply #6 on:
October 09, 2011, 06:38:51 PM »
Quote from: X Ring on October 09, 2011, 02:44:30 PM
Marty
+1 , you can use the accessory plugs, which are switched with power on, under the right side cover, for the relay trigger. Best of both worlds, IMHO.
R
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
