August 21, 2025, 10:40:28 PM *
Author Topic: Front fork question?  (Read 1715 times)
Ron44094
« on: October 12, 2011, 03:24:50 PM »
I have a 98 tourer and I need to replace the lower fork shaft!  It is connected to the axle yoke and I have a replacement lower shaft but the axle yoke is bad.  Is it possible to remove the bent shaft from the good yoke and put that yoke on the good shaft!  If possible, how?  Thanks!
tank_post142
south florida
« Reply #1 on: October 12, 2011, 04:57:58 PM »
yup. the tube threads into the lower.
I got a rock Sad
VRCCDS0246
Ron44094
« Reply #2 on: October 12, 2011, 05:42:29 PM »
Standard thread or reverse thread and any special technique to getting it apart?
Grumpy
Tampa, Fl
« Reply #3 on: October 12, 2011, 06:23:55 PM »
If you dismantle the fork, there is a hole through the spring tube, put a pin there to hold it, apply some hear to the aluminum lower part, and it should unscrew. Right hand threads. You do not need to get it real hot, just a propane torch, or even a heat gun will be enough.
