designer
« on: October 13, 2011, 08:08:49 AM » |
I have a custom fairing and it has spots for speakers. The openings are pre-marked for holes but I'm not sure what size speaker to purchase. 4" or larger. Can someone measure a speaker from screw hole to screw hole across the speaker and give me the distance on a 4" and if someone has a 5" measure the same...
I'm thinking its a 4", but the speaker hole is alot bigger then 4"
Thanks for any help
2002 Valkyrie Std K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: October 13, 2011, 10:00:15 AM » |
You say it's a custom, as in one of, or is it something you made fit? What brand of fairing?
Black Dog
Just when the highway straightened out for a mile And I was thinkin' I'd just cruise for a while A fork in the road brought a new episode Don't you know... Conform, go crazy, or ride a motorcycle...
« Reply #2 on: October 13, 2011, 11:50:22 AM » |
If you can fit 5-inchers in there, I've found they have significantly better sound than 4". In fact, I installed 5" Alpines in my Wing, what a difference over 2 different sets of 4" including Electrical Connection's and Blaupunkt. I had to do some cutting internally in the pods and on the speakers but it was worth the effort.
Steve K (IA)
« Reply #3 on: October 13, 2011, 12:38:46 PM » |
We need to know what "Custom" fairing you have. Are there mounting bosses / standoffs on the inside where the speakers are screwed to? Dimensions across those bosses would be a help also. A picture is worth a thousand words.
 States I Have Ridden In
designer
« Reply #4 on: October 13, 2011, 01:46:05 PM » |
sorry steve, I was trying to get some information before I got home. I'll get more detailed information tonight. The fairing is a hoppe that they no longer make. uses the current shield and has dimples in the fiberglass for screw holes... figure if I knew what a 4" speaker measurements across the mounting holes I could see if they fit. I'll measure mine and throw that out here and see who can match them. Seems I coudn't find a specification for the actual dimensions for speakers, only the audio specifications. I think smokin' joe has the same fairing.
Steve K (IA)
« Reply #5 on: October 13, 2011, 02:37:05 PM » |
OK. There is a specific speaker for this fairing, I have one on my Std. I done some checking to see if these speakers were still available, just in case, and they are. I think I saved this information to my computer. Let me do some checking. If I can't find it in this machine, I'll pull a speaker and look.
Steve K (IA)
« Reply #6 on: October 13, 2011, 04:13:25 PM » |
Well, had to pull a speaker. Here is what I found. The brand is SeaWorthy Sound Systems by Prospec. Model 5572BB Max power 40 watts. I can't find exactly what I have. The model numbers are slightly different. These have the same mounting hole diameter of 4 1/2" (what I have), listed as a 5" speaker, but higher wattage: I would not go any larger than a speaker needing more than 4 1/2" hole. They are molded one piece. This is the best price I found. http://www.shopepal.com/p-9522-seaworthy-sea5582b-5quot-speaker-black.aspxJust do a SeaWorthy Sound Systems and/or Prospec search. Here is Prospec's site. Send them with an email with your questions. There is a retailer in Vermilion, OH...Harbortown Marine. www.htmarine.com 440-967-8072 I hope this made life just a bit easier.  PS. The fiberglass appears to have been taped. I bought new screws when I got the fairing. 6-32 SS SHCS (stainless steel socket head cap screws) For first hand info, contact Glen Woods of Woody's Fairings. He designed and made all the Hoppe fairings for the Valk.
designer
« Reply #7 on: October 13, 2011, 05:42:14 PM » |
From screw hole to screw hole is 5 1/4 inches. fiberglass would require metal clip (I can find since I work at Honda fairly easy). Actually hole opening is 4 1/2". So, my concern is what size flange and hole spacing is on what speaker?! From hole to hole across the speaker the screws need to be 5 1/4 on center or close. fiberglass thickness is 1/8"
Steve K (IA)
« Reply #8 on: October 13, 2011, 06:49:03 PM » |
The measurement on mine is 5.150, just a little shy of 5 1/4. Opening is 4 1/2. If you get the speakers I gave you a link to, you should be set. Where did you find the fairing? They are hard to find. I think only 97 were ever made.
designer
« Reply #9 on: October 13, 2011, 07:31:19 PM » |
Got it from a board member. I'll have to look to see who it was. Going to get it painted this winter to match the bike. Thanks for the link!
¿spoom
« Reply #10 on: October 13, 2011, 07:54:46 PM » |
Yeah, those are 5" speakers, I measured the hole spacing (diag.) at 5.12" Those original Hoppe fairings had counterbored holes with # 6-32 nylok nuts epoxied into them to hold the speakers from behind. That one is either made by someone else or was repaired because the Hoppe never had that heavy cross-roving cloth on the windshield flange, they were all laid with 3oz. cloth. That 5572B speaker has been replaced by Prospec/Seaworthy with the 5582B. Different grill appearance and slightly less weight. Supposed to be a hair more efficient design, I can't tell the difference by ear. According to their website they still offer that earlier style in chrome as the 5572C like these ones;
« Last Edit: October 13, 2011, 08:00:03 PM by ¿spoom »
