August 21, 2025, 10:40:23 PM *
Author Topic: getting the boot back over the u joint  (Read 1216 times)
Spurs
Summerfield, FL
« on: October 14, 2011, 08:51:06 PM »
any suggestions as to techniques that are best for this job?  its a bugger with big hands to get in there and stretch it back on.
1997 Valk Std
2014 Indian Vintage
2016 Polaris Slingshot
Politicians and diapers need to be changed often and for the same reason. Mark Twain
Joe Hummer
Arnold, MO
« Reply #1 on: October 14, 2011, 09:50:52 PM »
A little WD40 on the lip of the boot, and spin it on.  Start one side of the boot and rotate it.  The rest of the boot will do on.  It has worked good for me the last couple of times I have had to put it back on.
Joe
1999 Valkyrie Interstate
« Reply #2 on: October 15, 2011, 04:35:11 AM »
I warm it up so its 'soft' and add some lube. I use pliers on the tabs. Once one end is started, I just spin it. Helps if the swing arm is near level.
Jeff K
« Reply #3 on: October 15, 2011, 06:21:25 AM »
Rubbing alcohol is the best lube for rubber. It will slide right on.
Mr.BubblesVRCCDS0008
« Reply #4 on: October 15, 2011, 07:10:53 AM »
Wait until you get the bike back on the side stand. The shaft angle will be in it's normal position and the jack being out of the way will give you more room to work. This has worked well for me in the past. Also knowing the correct words will help.
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #5 on: October 15, 2011, 11:21:36 AM »
Would those be the words not said around women and small children?  Roll Eyes  coolsmiley
F6Mark
2000 Red/Blk Tourer
College Park, MD
« Reply #6 on: October 15, 2011, 04:34:27 PM »
I recently inspected my u-joint for the first time and it took me a couple days to get the boot back on- what worked for me was getting it at ground level as mentioned below, and the other life saver provided by some saint on this tech board:  fold/roll the large end back on itself and then snug it up and unroll it over the opening...  this is how i was able to get it back on.
Good luck!
VRCC 6020
