August 21, 2025, 08:49:08 PM
cruise question
Topic: cruise question (Read 835 times)
plcae
cruise question
October 30, 2011, 06:13:05 PM »
my audiovox cruise blows my fuse? anyplace I should look first? was working fine since installed only not as sensitive as before. thanks for any help
Re: cruise question
October 30, 2011, 08:24:27 PM »
Check to see how sharp a bend you have in the cable running from the servo to the carb linkage. You don't want it less than about four inches across otherwise it will bind when activated. The other thing might be the connector that hooks the controller on the handlebar to the servo. If you have a Tourer or Std., that connector is open to the elements. I cut it off and soldered the wires together and insulated them real good. Then made my connections under the seat where it's all covered.
Just a couple ideas.
Mr Bojangles
Bonham Texas
Re: cruise question
October 31, 2011, 06:14:13 AM »
Does it blow at random times or does it blow (the fuse) as soon as you replace it?
BoJangles
Still on the right side of dirt, it is a good day!
=> InZane XXV
