November 23, 2025, 04:33:31 PM *
Author Topic: Want to make a jack adapter!  (Read 2390 times)
Ron44094
« on: November 01, 2011, 08:04:09 AM »
I have a Larin LATV-J jack and would like to fabricate a jack adapter.  Does anyone know of any plans that would help me do so?
Ron44094@yahoo.com
Thespian
Bonny lake Washington
« Reply #1 on: November 01, 2011, 08:23:51 AM »
 There are some on the shop talk page. cooldude
« Reply #2 on: November 01, 2011, 08:54:24 AM »
Here ya go!
There's even some dimensions for a wood type although I would not recommend such.
This is the link!
« Reply #3 on: November 01, 2011, 10:01:54 AM »
I made one of these.  I glued it with subfloor adhesive and screwed it together.  Been using it for years without issues.  Not my photo.
PAVALKER
Pittsburgh, Pa
« Reply #4 on: November 01, 2011, 06:41:29 PM »
Ron44094@yahoo.com
By chance did your Larin jack come with the ATV adapter plate?  Possible that you might be able to use that as well.
Edit... I don't believe your model came with it... but the Mal-2 did... and looks like this....
[img]http://www.motorcyclejacks.com/adapter.jpg[img]
« Last Edit: November 01, 2011, 06:44:54 PM by PAVALKER » Logged
John
« Reply #5 on: November 01, 2011, 06:45:04 PM »
I used the same plans to build mine....Works perfect and never a problem.
« Reply #6 on: November 01, 2011, 08:00:33 PM »
I've used this one for years with two bikes and never had a problem either.  Used pressure treat lumber for the uprights.  One inch pine for the base.
Editor's Note:
Each of these gentlemen used a thinner base board for the lift adapter, and after thinking about it, this makes real good sense.  The lift is directly under the heaviest part of the bike, and thus there is not much of a load on the base board.  Sure makes it easier to get the lift under the bike.
http://www.herberts.org/wayne/valk/lowtechlift.htm
Thrud
2000 Valkyrie Interstate
« Reply #7 on: November 02, 2011, 05:57:28 PM »
You want one of these:
http://www.ebay.com/itm/VALKYRIE-LIFT-JACK-ADAPTER-STURDIEST-STAYS-BIKE-/170622363419?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item27b9e2a71b#ht_1518wt_1239
I have one on my Interstate and am completely satisfied.  It stays on the bike and is virtually invisible to the casual onlooker.
Steve
Joe Hummer
Arnold, MO
« Reply #8 on: November 02, 2011, 06:05:00 PM »
Steve
I have recently installed these on both my wife's Tourer and my I/S.  They make a huge difference and is very stable.
Joe
1999 Valkyrie Interstate
« Reply #9 on: November 03, 2011, 08:47:01 AM »
I don't think I jack my bike up maybe a couple times a year so a permanent adapter (to me) is overkill.
That being said, I do stand my bike up many more times for all kinds of work.
When I stand the bike up I use bracing under the front crash bars which makes the bike very steady and much more stable.
Whenever I feel  it's necessary for even more stability I tie the handlebars with ropes fastened to the rear crash bars.
To enhance the stability of the bike whenever I have it off the side stand I wrap a small bungi cord around the front brake lever to lock the front wheel.
Locking the front wheel is a very good way to add stability to the bike whenever there is a chance of movement that can be dangerous.
PAVALKER
Pittsburgh, Pa
« Reply #10 on: November 03, 2011, 09:44:50 AM »
Steve
Joe
Got one on my I/S and love it.   cooldude
John
Gary
Northern New Mexico
« Reply #11 on: November 03, 2011, 10:33:10 AM »
Steve
Joe
Any idea if the below hidden air horn mount will be workable with the them?
